  #21 (permalink)
Old June 3, 2010, 02:00 PM
Silvgearx's Avatar
If your clocking the HT link you need more juice for the SB voltage. Or just keep the HTT within 2000mhz.
1.4 on CPU-NB is really high, are you sure your temperature are aright? CPU voltage on the other hand is a bit low for a 7xx series. switch it up with the CPU-NB.
Also since your clocking with HT turn up the NB volts and SB volts by 1. EG 1.2 for NB 1.3 for SB
Another problem might be dude to your PSU not having enough juice. These Phenom II are power hungry mother . Not 100% sure on the PSU and it be best to get a second opinion from an expert.
  #22 (permalink)
Old June 3, 2010, 02:46 PM
sswilson's Avatar
I'd second the idea of possibly changing the PSU, but your immediate issue of 5 hr prime fail indicates that you're pretty damn close to stable. Anything beyond 2 hrs usually means that it's only a small voltage tweak away.......
You can also try jury-rigging a 120mm fan over your chipset cooling to rule out overheating on those components.
  #23 (permalink)
Old June 3, 2010, 03:43 PM
^^^ Thx everyone! I figured-out what was wrong...stupid me.
I had CPU-NB voltage at 1.4V, but my RAM was 1.8V only, not 2.1V as I indicated above. So, I bumped-up the RAM voltage to 2.1V. Ran Prime95 since this morning, and it ran for 11 hours and 21 minutes with no errors and no warnings!!!
Woohoo! Yeah! Finally!
Pushing 4 cores @ 3.25GHz, and RAM @ 1000MHz. Final settings I used:
FSB 250
Multiplier 13x
CPU-NB Voltage 1.4V (***EDIT*** Brought this down to 1.325V...ran Prime95 for 10 hours...stable)
CPU-NB Frequency 2250MHz
HTT Frequency 1800MHz
RAM Frequency 400
RAM Timings 5-5-5-18
RAM Voltage 2.1V
  #24 (permalink)
Old June 11, 2011, 08:06 AM
super thread revival...
Pushing 4 cores @ 3.6ghz, and RAM @ 1477mhz...P95 blended for 15 hours stable...20 passes of IBT @ max...
FSB 277mhz
CPU Multi 13x
NB Freq 2216mhz
RAM Ratio 5.33x @ 738.6mhz @ 7-7-7-20 @ 1.8V
CPU-NB Voltage 1.5V
CPU-NB VID Control Normal
NB Voltage Control Normal
All thermal settings disabled
Core temp @ idle 26C
Core temp @ load 53C
CPU temp @ idle 39C
CPU temp @ load 66C
Room temp @ 22C
help me unlock my 4th core..! ultraman7k Overclocking, Tweaking and Benchmarking 8 May 31, 2010 08:42 PM
Core Unlock Switch? jcmaz CPU's and Motherboards 10 March 13, 2010 08:43 AM
Successful 550 unlock (i think) johnnyblazzwa Overclocking, Tweaking and Benchmarking 17 March 4, 2010 10:17 AM
AMD unlock phil3_66666 CPU's and Motherboards 5 November 17, 2009 06:46 PM
Help!! I can't unlock these RAID Drives!? bushwickbill Troubleshooting 38 July 30, 2008 10:51 PM
