Old May 31, 2010, 05:37 PM
Mook06's Avatar
one of my 550's unlocked to quad is running at 3.5GHZ, stock volts... the cpu will go up to 3.7GHZ with 1.4v~ or so perfectly stable but the current combo of ram/mobo doesnt wanna play nice at those speeds
it has a ocz vendetta 2 cooler, it ran way to hot with stock cooler, i think this chip was simply out of spec thermal wise to be sold as a higher end quad
Old May 31, 2010, 07:52 PM
MobiusD's Avatar
Buy a black editon cpu, try it again, i bet itll work
Old May 31, 2010, 08:21 PM
^^^ LoL! I guess a BE would solve the problem too.
Mook, u may be rite. Anyway, just glad i manage to squeeze the 4th core out. Better than nothing i guess, :).
Old May 31, 2010, 09:15 PM
Have you tried overclocking with just 3 cores? that might help narrow down your problem a little bit.
Also, here's a guide that I used to overclock my Phenom 2, Dolk's Guide to the Phenom II - TechREACTION.net Forums
Old June 1, 2010, 05:42 AM
^^^ Hummmm, I have not come across that website b4. Interesting, I'll give it a try.
Gonna try fiddling with the RAM timings again, the dude suggests 5-7-7-27-32 for 1066MHz in 64-Bit enviro. I'm already running my RAM Voltages at 2.1V, so maybe I'll try 2.3V. I'll try keeping my CPU-NB around 1900 - 2000, and try to bump the FSB from 200 to 230, to see if I can get up to 3GHz.
I'll let u guys kno. LoL, so exciting. Thxthx.
Old June 1, 2010, 06:08 AM
^^^ Ok, i'm back. That could mean either of 2 things, either i was still unsuccessful in OC'ing, or I managed to bump it up a bit.
drumroll please... I managed to bump the FSB from 200 to 215, before being unable to POST, using those RAM timings and voltages. Woohoo!
Just need to run Prime95 for a few hours and see what happens. CPUz is showing 2795MHz with 4 Cores still active. 195MHz more is better than nothing, :).
Gonna try to play around with the CPU-NB (NB Speed) later on, and see if i can get more juice out of it. Maybe lower the speed there to 1900, as it's showing 2150 rite now in CPUz. Wish me luck!!!
Old June 1, 2010, 06:56 AM
^^^ Bleh... I knew it was too good to be true.
Prime95 failed three minutes into testing. Then followed by BSOD. I quit!!!
Old June 1, 2010, 09:09 AM
^^^ Ok, so I didn't quit just yet.
I managed to get a meager 5% overclock, from 2.6GHz to 2.73 GHz. Running stable so far, with no problems from Prime95 yet.
From the article, I had to check my max FSB, so I did that. The most stable was 210 @ 12.5x, I couldn't even get 215 @ 12x.
So, I left it at FSB 210, using 13x, 1.325V. Didn't have to change my voltage settings, nor RAM timings.
Seriously, am I doing something wrong? At first, I really wanted to see if others had the same problem, but now, I'm really frustrated the more I try, LoL.
  #19 (permalink)
Old June 1, 2010, 10:45 AM
^^^ Woohoo! I figured-out what I was doing wrong!
I friggin' forgot to change the ram speed settings. I downtuned it from 533 to 400, keeping the same timings (5-5-5-18), and lowered the voltage from 2.1 to 1.8. I set the FSB to 250, multiplier to 13x, CPU-NB Frequency to 9x, HTT Frequency to 1800.
So, now my CPU runs at 3.25GHz, and ram speed is 1000MHz. Prime95 running fine so far. Temps lookin' good.
  #20 (permalink)
Old June 3, 2010, 08:38 AM
ARGGLE... I'm back. Prime95 conked-out after five hours and 40 minutes.
Bumped the CPU-NB Voltage to 1.4V and RAM Voltage to 2.1V. Ran Prime95 again. Conked-out again after five hours and 15 minutes.
Any ideas?
Should I crank-up the CPU-NB frequency to 2500MHz & HTT frequency to 2000MHz? Or,
Should I lower the CPU-NB frequency to 2000MHz & HTT frequency to 1600MHz?
help me unlock my 4th core..! ultraman7k Overclocking, Tweaking and Benchmarking 8 May 31, 2010 08:42 PM
Core Unlock Switch? jcmaz CPU's and Motherboards 10 March 13, 2010 08:43 AM
Successful 550 unlock (i think) johnnyblazzwa Overclocking, Tweaking and Benchmarking 17 March 4, 2010 10:17 AM
AMD unlock phil3_66666 CPU's and Motherboards 5 November 17, 2009 06:46 PM
Help!! I can't unlock these RAID Drives!? bushwickbill Troubleshooting 38 July 30, 2008 10:51 PM
