Old May 28, 2010, 02:14 AM
llama_egg's Avatar
Default Help with I7-920 OC before I hulkify
Originally Posted by System
CPU Type QuadCore Intel Core i7 920, 3700 MHz (21 x 176) (C0 stepping D: )
Motherboard Name Gigabyte GA-EX58-Extreme (2 PCI, 1 PCI-E x1, 1 PCI-E x4, 3 PCI-E x16, 6 DDR3 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Motherboard Chipset Intel Tylersburg X58, Intel Nehalem
System Memory 6144 MB (DDR3-1066 DDR3 SDRAM)
DIMM1: OCZ XTC Platinum OCZ3P1600LV2G 2 GB DDR3-1066 DDR3 SDRAM (7-7-7-16 @ 533 MHz) (6-6-6-14 @ 457 MHz) (5-5-5-12 @ 380 MHz)
DIMM3: OCZ XTC Platinum OCZ3P1600LV2G 2 GB DDR3-1066 DDR3 SDRAM (7-7-7-16 @ 533 MHz) (6-6-6-14 @ 457 MHz) (5-5-5-12 @ 380 MHz)
DIMM5: OCZ XTC Platinum OCZ3P1600LV2G 2 GB DDR3-1066 DDR3 SDRAM (7-7-7-16 @ 533 MHz) (6-6-6-14 @ 457 MHz) (5-5-5-12 @ 380 MHz)
Seriously ramming my face against my keyboard for the last couple of days hoping that the values that would come up might actually work.
This adventure of OC'ing has become level's upon level's of frustration as I try (horribly) and get as close to 4.0ghz as I humanly can, or should I say try and get it to even boot with higher clock speeds. The current overclock? Oh, that's with me upping the BLCK to 176 and keeping turbo on. That's it. Everythnig else is kept at automatic. Figured it shouldn't be too hard to manually increase voltages and get the thing up to 3.9-4.0, hell, shouldn't be that hard to get to 3.8.
Apparently it is that hard. Rabble rabble rabble.
I've cranked voltage levels only to get it to crash on the windows screen, which is frustrating to say the least, but it get's worse. Unless I've misread something somewhere, if I even touch my QPI/VTT voltages, it doesn't boot. I have to reset my CMOS to even get my computer to start, at least when I keep it on automatic I'm able to watch my computer crash as it cries in pain.
Hell, I've tried some insane values just to try and get my computer to be stable enough to log into windows; as a prime example.
BCLK: 203x19
VCORE: 1.4-1.5
PLL: 1.88
DRAM: 1.5
IOH/ICH: 1.2
QPI/VTT: 1.4 (doesn't boot) QPI/VTT: Automatic (crashes on windows splash screen)
Anywho, anyone have any idea's? I've fiddled with options, voltages, turned off turbo mode, even touched things I've never heard of before.
Seriously people, I am not a mod. Stop messaging me D:
Old May 29, 2010, 10:07 PM
llama_egg's Avatar
I'm guessing the fact that this has had over 90 views over the course of two days without a single comment means I'm a lost cause? :\
Old May 29, 2010, 10:27 PM
rjbarker's Avatar
I'd try n help you out, but that aint my Board....Evga classy here...if you had the same I'd be able to help you out, not familiar with the BIOS on that Gig Board...lots of folks here are familiar with those gig Boards...surprised they haven't chimed in...
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old May 30, 2010, 05:58 AM
gingerbee's Avatar
the first thing you can do is turn off turbo get it running on a x20 then lower that pll 1.88 should be up words of 4.7. try running it with out turbo on this board adn see if it's any better. the x20 should help a lot it really messes up the giga-board because it leaves it on all the time.
just to let you know that gigabyte boards normally don't do that great on auto you have to set the main voltages
my settings that are totally stable go's as
for 4.0ghz 4.2 4.4
LL calibrate enable enable enable
cpu vcore 1.26 1.31 1.35
qpi/vtt 1.25 1.3 1.35
IoH core auto auto auto anything higher then 4.4ghz needs a boost from auto to 1.2 to a max of 1.3
dram 1.5 1.5 1.5
pcie auto auto 101-102
qpi/pll 1.78 1.8 1.8
IoHcore auto auto 1.2
IcH I/O auto auto auto
IcH core auto auto 1.1
hope this helps at all good luck this chips oc really easy it just takes some getting used to my D0 will do 4.7 on 1.4 great chips. this is all on water
gtz block with a mcr.120.3 swiftech edit sorry i did lay it out right it just put it back
Old May 31, 2010, 10:44 AM
llama_egg's Avatar
Still nothing. Even ignoring the fact my board won't hit the same voltages for some thing (qpi/pll for example), or the fact that my board won't boot if I touch qpi/vtt still, the most I can get with massive playing around is get it to crash on the windows login screen; which I suppose it farther than before.
Starting to think I got either the worst CPU in the batch or something is wrong with my mobo. :\
Old May 31, 2010, 11:02 AM
gingerbee's Avatar
have you updates the bios? solved a lot of early problems that some had. do you have your uncore running isochronous support to enable.
Old May 31, 2010, 11:24 AM
chrisk's Avatar
Folding Captain
I see you have a Gigabyte Board.
Their unofficial support forum is at tweaktown...there are a few Gigabyte engineers who hang out there. LSDMEASP is a mod who hangs out there who has great success helping folks.
Fold for team #54196
Old May 31, 2010, 11:27 AM
rjbarker's Avatar
What is the rated spec speed of your RAM and what are you trying to run it at? Have you bumped up your vDimm from 1.55v to 1.65v? Something aint right....you should be able to get to your Desktop at a moderate OC without crashing, even with a poorly binned CO Chip.....
Timespy: 18.613K
MARK 11: 40.185K
Old May 31, 2010, 11:29 AM
gingerbee's Avatar
^my thoughts,even with the worst binned chips
Old May 31, 2010, 03:17 PM
rjbarker's Avatar
^^^ Yeah I can get my crappy ole CO Chip to 4.3 Ghz with a successful Bench run .....I know it aint "stable", but not that unstable.....
Sounds like he maybe not getting his Bclk inline with his RAM Ratio.....obviously if his RAM is set wayyyyy to high it will crash immediately or not Post at all.....just a thought...
Timespy: 18.613K
MARK 11: 40.185K
[WTB] i7 920 3.0charlie Buy/Sell & Trade 8 January 5, 2010 07:48 PM
[WTB] i7 920 kyle_L Buy/Sell & Trade 1 November 23, 2009 07:59 AM
I7 920 is there HT elec999 CPU's and Motherboards 3 June 2, 2009 05:42 AM
help me WC a i7 920? go flames go Water Cooling 16 April 10, 2009 07:22 AM
