Old May 27, 2010, 01:19 PM
burebista's Avatar
Default Overclock or Underclock for gaming?
Guys please before I loose my mind explain to me this.
AvP benchmark. CPU stock
CPU OC
CPU underclock
How in the name of God I have 47 FPS with 1.6Ghz CPU and 32 FPS with 3.5GHz CPU?
CPU is perfect fine, stable in any stability tests or games. It looks normal in HyperPi or Realtemp Bench but in games results are crazy if I OC it.
Same results like AvP I have in STALKER:CoP benchmark or Stone Giant. Basically 17% CPU OC = -15% FPS in those. It's insane.
I'm not an OC-er but I'm curious about this anomaly.
If it ain't broke... fix it until it is.
Old May 27, 2010, 01:43 PM
gingerbee's Avatar
well there's a problem because i can run hyper pi and the higher my ghz the better my scores are. for the other benchmark i have not used it so i can't speak.
Old May 27, 2010, 02:10 PM
sswilson's Avatar
Maybe there's an automatic quality degredation based solely on perceived clock speed that allows for higher fps at lower clocks? Doesn't make much sense but that's the only thing I can come up with.
Old May 27, 2010, 02:44 PM
did you screw up your memory speed and/or timings when you oc'd?
Old May 27, 2010, 06:22 PM
Silvgearx's Avatar
Are you using 10.5? Maybe its a bug.
Old May 27, 2010, 06:30 PM
look up other benches. if same, then play a ticket and win the 40 mil for sure
Old May 27, 2010, 07:44 PM
ZZLEE's Avatar
Default Intel Drivers
If you can play windowed game. Try Ctrl/ALT/DEL, task Manager, Preformance, Resorce Monitor, CPU
and see if your Intel drivers are paking a core at higher clocks and not at lower clocks
play around with Recorce monitor it tells you what your computer i doing
carful not to X anthing out unless you realy know what it is !
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 27, 2010, 09:40 PM
burebista's Avatar
First of all thanks for replies.
Second I OC with SetFSB. 3.5GHz is maximum for my maximum VID (1.225).
I'll try to OC directly from BIOS.
HyperPi/SPi looks fine here too. Higher clocks->lower times. Good.
SetFSB to be the culprit? But why CPU benches are OK?
Yup, that 10.6 leaked (8.740). Damn, now 10.6 Beta 2 is out (for XP though).
I'll try. Both.
I know what I'm doing because I'm a monitoring freak. In weekend I'll put Riva at work and I'll monitor everything.
For now I was just curious why my rig is better with CPU lower frequencies.
LE: I see something interesting in AvP benchmark. Higher the clocks->lower the Number of frames .
Old May 27, 2010, 11:04 PM
My wild guess at this problem is that when you use SetFSB, you can screw up the ability of the internal timers to correctly measure time so if your computer can not accurately measure elapsed time then it can not accurately calculate the frames per second numbers.
Just a wild guess. To test this theory you would need to run the same 3 benchmarks at the same MHz but set the MHz in the bios and don't use SetFSB.
The other benchmarks you've posted show that the CPU is running faster when you overclock like it should be. Maybe something is built into this benchmark to punish anyone that tries to cheat by using SetFSB. Try finding another benchmark. How about the heaven one?
Edit: I multiplied the FSB times the FPS numbers and got 12747, 12717 and 12647. I think this bench is using the wrong internal timer to measure time and SetFSB is confusing it.
Old May 27, 2010, 11:27 PM
burebista's Avatar
Kevin it looks like a winner not a wild guess.
Agree, I'll do that in weekend.
Benchmarks that are not relying on CPU are perfect fine. Unigine 2.0 and GluxMark.
Kevin you're my hero as usual. Your explanations make perfect sense. I'll backup them with data in this weekend.
But AvP is not the only one which is crazy.
STALKER:CoP stock
STALKER:CoP OC
Stone Giant (first two runs stock DoF on/off and next two runs OC DoF on/off)
My First Overclock Cardboard box with DSL Overclocking, Tweaking and Benchmarking 11 April 11, 2012 05:11 PM
Help overclock Kappy Overclocking, Tweaking and Benchmarking 10 September 2, 2008 01:58 PM
overclock evzonas CPU's and Motherboards 2 August 31, 2008 04:49 PM
24/7 Overclock? bushwickbill Overclocking, Tweaking and Benchmarking 5 August 25, 2007 04:32 PM
Well I got one, now how do I overclock it? Supergrover Off Topic 11 May 1, 2007 02:30 PM
