Old May 27, 2010, 04:34 PM
Originally Posted by tri5cui7 View Post
Why not post a link then.
Because I wasn't trying to turn this into a discussion about how temperature measurements and specifications are handled with regard to Intel CPUs. In any case, the information is fairly easy to find either by searching for my posts or simply looking it up yourself.
It's pretty rude to say
NOT RIGHT
that doesn't mean you're right, just being rude. I'd take Intel's word over NOT RIGHT any day.
I never said "NOT RIGHT". As for trusting Intel's word over mine, that will not be necessary. My comments are coming straight from Intel. People who quote the thermal spec as a maximum temperature are not contradicting what I am saying, they are merely misinterpreting the significance of that value (which has absolutely nothing to do with the maximum safe temperature).
Old May 29, 2010, 01:10 PM
Socrates_Johnston's Avatar
I think I'm going to purchase this ram kit:
Newegg.ca - CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5DHX
I guess my board can support DDR2-1200 RAM, would it be worth trying to find some? or maybe get 1066?
how about these:
Newegg.ca - Kingston HyperX T1 Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model KHX8500D2T1K2/4G
I am looking to buy ram with a heat spreader so I can make my corsair ram cooler as effective as possible
Old May 29, 2010, 01:16 PM
There's no point in spending that much on DDR2, especially for slow DDR2. I suggest you go for a cheaper kit of DDR2-1000 or better, like this for example: Newegg.ca - OCZ Blade Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory Model OCZ2B10664GK
Old May 29, 2010, 06:22 PM
tri5cui7's Avatar
Since I'm here I'll ask a question. I have my q6600 at 3.2 and am currently using kingston value ram. I've been having a hard time getting it to 3.6, is it my ram holding me back or just the luck of the draw with my q6600. it's a go, I believe.
Old May 29, 2010, 08:40 PM
What's the speed of your RAM and what FSB speed are you trying to use? Unless you're going past the rated frequency of the memory, the RAM shouldn't have any limiting effect on your overclock.
Old July 4, 2010, 04:36 PM
update:
I recently installed my NH-D14 (it is a beast), and some mushkin blackline ddr2 1066 and I was able to hit 3.6ghz at 1.4v (all other settings auto) on my first try. It has been stable since then (passed intel burn test never getting any hotter than 70C and passed roughly 4 hours of p95 remaining much cooler)
hows my overlclock? flightsimnerd Overclocking, Tweaking and Benchmarking 13 January 2, 2010 07:10 AM
[WTB] Q6600 Zero82z Buy/Sell & Trade 0 November 30, 2009 11:49 AM
[WTB] Q6600 G0 anabioz Buy/Sell & Trade 5 June 23, 2009 03:07 PM
[WTB] Q6600 Phobia Buy/Sell & Trade 0 February 12, 2009 10:19 AM
[WTB] Q6600 anabioz Buy/Sell & Trade 17 December 11, 2008 05:59 PM
