Old May 15, 2010, 01:19 PM
encorp's Avatar
Default Core Temp on boot
I've enabled all the settings within core temp; of course I have UAC running so maybe that's the issue here but I'd like core temp to load on boot and drop to system tray for me. I've set up every setting within core temp and it still won't do it.
Ideas?
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
Old May 15, 2010, 01:42 PM
It won't startup for me either, so I stuck the shorcut in my startup file.
Old May 15, 2010, 01:56 PM
encorp's Avatar
Does it trigger the stupid UAC crap when you toss it in there?
Old May 15, 2010, 02:59 PM
It does for other people using my comp. But I don't really care about that.
Old May 15, 2010, 03:04 PM
SugarJ's Avatar
2 words.
Batch file.
Edit: Here's the contents of mine. I have a shortcut to the .bat in my startup folder.
@ECHO OFF
START C:\ProgramFiles\CoreTemp64\CoreTemp.exe
Old May 15, 2010, 03:07 PM
sswilson's Avatar
Batch File?????
Somebody's showing their age.....
Old May 15, 2010, 03:11 PM
SugarJ's Avatar
Originally Posted by sswilson View Post
Batch File?????
Ya, well, you know what it is too. Sometimes the old stuff works the best.
Old May 15, 2010, 03:13 PM
You may as well just stick a shortcut to Core Temp in your Startup folder. It accomplishes the same thing in a cleaner fashion. Although, anyone who is using an Intel CPU should really be using Real Temp anyway.
Old May 15, 2010, 03:17 PM
encorp's Avatar
Real temp only shows three cores for me :P And I can't figure out why lol. I should have thought of the batch file hahaha. Thanks!
Old May 15, 2010, 03:18 PM
That's because you're using Real Temp GT you dunce . Run the normal EXE and it will work.
Real Temp or Core Temp or Ai Suite Jhayman CPU's and Motherboards 11 November 19, 2009 11:11 AM
CPU temp vs Core temp phil3_66666 Air Cooling 4 July 31, 2009 09:39 PM
Real Temp or Core Temp ?? FrankyG Overclocking, Tweaking and Benchmarking 11 September 29, 2008 11:24 PM
Core temp's ? Unklmo CPU's and Motherboards 18 August 23, 2007 02:18 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
