Old May 15, 2010, 03:22 PM
Originally Posted by Zero82z View Post
That's because you're using Real Temp GT you dunce . Run the normal EXE and it will work.
Hahahahaha.
Okay; well I did... still don't see how to load real temp into system tray now @_@ lol
I'm feeling really stupid right now ahaha
Old May 15, 2010, 03:24 PM
SugarJ's Avatar
I've been using Coretemp because it displays the temps on the screen of my G15 keyboard. Does Realtemp do that now?
Old May 15, 2010, 03:29 PM
Not that I see.
Old May 15, 2010, 03:30 PM
Originally Posted by encorp View Post
Hahahahaha.
Go into Settings and check off the Show Icon option for each core in the System Tray Settings area...
I have no idea and I don't have a G15, but you could always have a look and see if there's a plugin for that or something.
Old May 15, 2010, 03:33 PM
SugarJ's Avatar
You may as well just stick a shortcut to Core Temp in your Startup folder.
It used to come up with an error in Vista when I did that. Something about unsigned drivers, IIRC. That's when I started using the batch file. But I just tested dropping the shortcut in the startup folder in Windows 7, that works now. I do have UAC disabled, don't know if it would puke if I enabled it or not.
Old May 15, 2010, 03:41 PM
Just tried that; and it just didn't bother to even try to load core temp. lol
Old May 15, 2010, 03:54 PM
gingerbee's Avatar
all i do is copy the shortcut of the .EXE into the startup folder like others have said works fine for me but i always turn off UAC.
Old May 15, 2010, 04:28 PM
Tried that; no dice.. won't even load enough to ask me for the UAC.
Edit: Works either way if I turn UAC off; either dragging into startup folder or through core temps settings, bah.. I kind of like the little UAC guy.
  #19 (permalink)
Old May 16, 2010, 12:05 AM
burebista's Avatar
If you're using RivaTuner it does via RealTemp plugin.
If it ain't broke... fix it until it is.
Real Temp or Core Temp or Ai Suite Jhayman CPU's and Motherboards 11 November 19, 2009 12:11 PM
CPU temp vs Core temp phil3_66666 Air Cooling 4 July 31, 2009 09:39 PM
Real Temp or Core Temp ?? FrankyG Overclocking, Tweaking and Benchmarking 11 September 29, 2008 11:24 PM
Core temp's ? Unklmo CPU's and Motherboards 18 August 23, 2007 02:18 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
