Old May 15, 2010, 09:33 AM
Default Simple OC question.
Hey,
If I OC the 1055T to 3.6Ghz, will I have the performance of a 1090T ?
I know this sounds like an idiot question, but it probably is
Old May 15, 2010, 09:37 AM
martin_metal_88's Avatar
Originally Posted by Thalmaray View Post
Hey,
Well it's the same CPU clocked at different speed at all...your 1055 at 3.2 should ( in theory ) have the same power so at 3.6 it is suppose to be a little over in power. But, is there anything better then test it and tell us No seriously...at 3.6 you will definitly have better performance.
Simple question. clone63 CPU's and Motherboards 3 March 26, 2009 07:48 PM
RAM Installation (really simple question) shryke RAM 9 October 28, 2008 03:00 AM
Simple Question Scutum_Deus CPU's and Motherboards 8 September 22, 2008 06:31 AM
A simple and complicated question Scutum_Deus New Builds 2 September 22, 2008 03:03 AM
Quick Simple question mattydies Overclocking, Tweaking and Benchmarking 3 October 19, 2007 06:44 PM
