Old May 14, 2010, 06:16 AM
poroporo's Avatar
Default Temperatures on an x2 555
I'm relying on TMPIN0 for my X2 555's temps, but should I interpret the actual core temperature to be higher, or lower ?
Right now I'm idling at 38 and maxing at 63 under prime95 small FFTs. It was unstable at 1.4v offset, I brought it to 1.42v manual and it's stable, however I'm still concerned about the temps.
Ideas ?
Old May 14, 2010, 06:36 AM
there could(is) a bug with the readings on a number of chips, probably mine included. 1.4v idles at 24 lol. not stock cooelr, but c'mon!
if it dont crash, no worries.
Old May 14, 2010, 06:41 AM
poroporo's Avatar
Well I would have accurate sensor readings if it wasn't unlocked, but then that's not the point I guess .
Lowered voltage to 1.41, cpu-z shows 1.440. Load temp dropped to 60 under prime.. got 3 degs back.
Old May 14, 2010, 07:27 PM
cool. i noticed on me giga, as soon as i started working with the +- in the special section the readings went tru the floor or the roof.
AMD X2 555 BE unlocked to 4 cores Hunt CPU's and Motherboards 12 April 5, 2010 10:50 PM
Phenom II 555 puroman1 CPU's and Motherboards 1 February 3, 2010 05:04 PM
Are these temperatures ok? what can I do to lower them? mtrpcic Overclocking, Tweaking and Benchmarking 3 October 19, 2009 11:53 AM
Q9550 Temperatures lKashl Troubleshooting 6 July 9, 2009 11:32 AM
