Old May 11, 2010, 06:30 AM
AmuseMe's Avatar
Originally Posted by gingerbee View Post
heat does not kill chips voltage does. anything under 80c. jmo
Well, they kind of go hand-in-hand. Want a higher overclock? Crank the voltage. Crank the voltage, you geat heat. Although, there are those 'golden' chips that can overclock good at low voltages.
Old May 11, 2010, 09:26 AM
Patramix's Avatar
no one as suggestion the CM 212+ cooler, OC'ing or not, at 22-25$ its hard to beat, plus its keeping my i5 750 @3.8ghz under 69C(with 2 r4 fans 5$ each) with full load after 20hours
even with the stock fan the 212+ will keep your CPU happy.
coretemp, real temp they all do the same job, its only a matter of personal tast IMO
Prime95- just open it, hit the small or large FFT option then hit OK, and let it run for a while, to stop it, click on test->stop test and then exit.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Old May 11, 2010, 09:42 AM
gingerbee's Avatar
Originally Posted by bojangles View Post
You CPU is running great.
@gingerbee: for the most part yes, however temperature can degrade the chip over time. For the most part a CPU/GPU will throttle itself if it gets too hot and stay within a certain threshold. But, alas, who cares if you've taken one year off of the 15 year lifespan of the chip :).
very true so if you buy your stuff from the recycle guy then you may have some problems other wise hehe i hear what your saying and no one will run any cpu that long i have people who run heavy oc Pentium 2 and 3 and they just keep on ticking most of the time i have found that the board goes long before the chip does.
but this is a given side effect of overclocking everyone who oc should know this and put cooling to allow for it. jmo
Old May 11, 2010, 03:04 PM
Wow thanks guys, the CM 212+ looks great and it will give me the temp that I want, plug I probably won't OC at least for another few months. :)
Old May 11, 2010, 05:22 PM
Yes, but the heat is not dangerous to the CPU. Overvolting a CPU is the only way to damage one under reasonable circumstances.
Old May 22, 2010, 12:56 AM
I like to keep the CPU temps below 60C, and in the summer u should pay more attention to the temps obviously. If u wanna OC a lot the key is simply a nice CPU heatsink and good ventilation, but below 60C u should be fine
Phenom II X2 550 BE the new "best bang for buck" CPU? GregH CPU's and Motherboards 11 August 8, 2009 04:10 PM
CPU temp vs Core temp phil3_66666 Air Cooling 4 July 31, 2009 09:39 PM
What is this button on the "Real Temp 3.00 " App mean? bushwickbill Overclocking, Tweaking and Benchmarking 0 May 21, 2009 08:23 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
