| BALISTX'S Intel E2180 Overclock ![]() ![]() ![]() ![]() Intro When I originally got my system I tested outside the case and was able to get a 2.8GHz overclock from the stock 2.0GHz at stock voltage. Once I discovered my PSU was bad when I put it inside the case I decided when I got the PSU back last week from RMA I would run it at stock for a while. So today I got the urge to OC it again. I tried putting it to 2.8GHz but it crashed on loading windows. So I decided to start off at 2.6 and here is the story. Quote:
![]() It was stable running Super PI Overclocked to 2.7GHz ![]() Again running Super PI it's stable. Overclocked to 2.8GHz It crashed loading windows at stock volts. Overclocked to 2.75GHz ![]() Ran Super PI it was stable. 3DMark 06 Test ![]() I was surprised my score wasn't higher I do not know what is bottlenecking me. Quote:
I am currently at stock voltage of 1.2 vcore and I since I only have the stock Intel HSF I do not want to up the voltage until I get a better cooler. For right now 2.75GHZ from 2.0GHz is a decent OC for me. I have not ran Orthos yet but I will tonight when I am at the hockey game and see if it is truely stable at 2.75GHz.
__________________ "Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded." Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12 EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl [Heatware] BALISTX.com |
Thats a decent OC for a stock cooler. Youll have to work out what to do with that extra cpu power! Bioshock maybe?
__________________ E6750/ Xeon 3350 DFI X38 LT 2 x 4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black). Loop 1: MCR 220 int. ; Apogee GT block. Loop 2: MCR 320; Swiftech Res.; 2x EK FC blocks. Pumps: 2x MCP655. |
Yup, follow Lithotech's comments and you're good to go. Don't forget to disable Speedstep (E1ST). My E2140 did 3.0 easily with the Arctic Cooling 7Pro. Yours can do better, for sure. John
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
I went into the BIOS, and turned off all the power management and that seemed to make things run more stable. The vcore in CPUZ went to 1.16v which in the BIOS it's showing as 1.2v Temps are running good at 29, 30 at idle. Here is a screen shot I took during a Super PI test. You can see the load temps.
That's pretty good, considering the very low voltage! Slap on an after-market HSF, and that chip will show its true potential.
When I was running Sandra SiSoft it got the temps up to 46C, 47C I'm going to run an instance of Orthos, but I don't want to push it too much right now with inadequate cooling. I only have two case fans a 120mm exhaust and an 80mm on the side blowing air in over top the processor and ram. My 120mm intake was killed by my defective PSU.
I ran a mini stress test of an hour with Orthos SFF CPU test and the temps never rose past 55°C for both cores in Core Temp and 53°C for both cores in Intel TAT.
__________________ ASUS M2N-E AMD 64 X2 4600+ @ 2.4 + AS5 + AF64 PRo OCZ Platinum XTC PC2-6400 2GB DDR2 800Mhz XFX 7900GS 256/256 Seagate 320GB 7200.10RPM OCZ GameXStream 600W Acer AL1916 http://www.xfire.com/profile/0mgwtfz0r/ |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Overclocking e2180 experiences | Mr. Cipher | Overclocking, Tweaking and Benchmarking | 16 | March 19, 2008 07:36 AM |
| temp. monitoring utilities and e2180 | nikitos | Overclocking, Tweaking and Benchmarking | 18 | January 15, 2008 02:12 PM |
| donimo's e2180 o/c log | donimo | Overclocking, Tweaking and Benchmarking | 19 | January 13, 2008 04:09 PM |
| Intel P4 3.0 Northwood Overclock | enaberif | Overclocking, Tweaking and Benchmarking | 4 | March 3, 2007 01:56 AM |
