Old November 10, 2007, 02:00 PM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
Damn, I wonder he is running for a cooling setup. I'm thinking it's gotta be a WC setup.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
Old November 10, 2007, 03:03 PM
omgwtf's Avatar
Level up: 74% Level up: 74% Level up: 74%
Level: 15 - 171 points to level up
That's for sure but still it's pretty impressive 3.9 with a E2180
ASUS M2N-E
AMD 64 X2 4600+ @ 2.4 + AS5 + AF64 PRo
OCZ Platinum XTC PC2-6400 2GB DDR2 800Mhz
XFX 7900GS 256/256
Seagate 320GB 7200.10RPM
OCZ GameXStream 600W
Acer AL1916
http://www.xfire.com/profile/0mgwtfz0r/
Old November 10, 2007, 04:30 PM
Keep in mind that could have been a suicide shot...I don't trust standalone cpu-z verification. I could verify my e2180 at 3.5, but 3 seconds after I turned Orthos on I had errors!
I keep on reading that the max voltage is 1.35v, however on Intel's CPU Spec Finder, the max listed is 1.5v. Any know the cause of the discrepancy?
Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900.
Intel E1xxx & E2xxx OC Thread
Old November 14, 2007, 12:58 PM
Lithotech's Avatar
Level up: 34% Level up: 34% Level up: 34%
Level: 11 - 222 points to level up
Those temps are just fine for a stock cooler -- one of the bigger chips would idle at those temps.
Interesting to note that 2.7ghz was all I could get out of my e2160 with stock volts.
Not sure about the spec sheet, looking it up now...
Core Temp will give you the cpu's rated maximum voltage, this shows up in the VID field.
Core Temp E2160 stock 1.8ghz 1.3volts under full load with Folding at Home:
(Reads 1.297v in CPU-Z, and 1.17v at idle with C1E and Speedstep etc)
Core Temp E2160 2.7ghz 1.3volts idle:
(Reads 1.297v in CPU-Z)
eVGA 680i SLI (A1) P31
Intel E6750 Conroe 1333 G0 SLA9V L723B134 | Scythe Ninja-B | Antec Tri-Cool 80cfm
2x1024MB Crucial Ballistix Tracer 8500 | 5-5-5-15 1066mhz @1.9v
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
Old November 14, 2007, 01:26 PM
Lithotech's Avatar
I can't find any voltage data on Intel's site, probably why I don't go there much.
Found this though, wiki is your friend:
List of Intel Pentium Dual-Core microprocessors - Wikipedia, the free encyclopedia
Old January 12, 2008, 09:15 PM
Level up: 9% Level up: 9% Level up: 9%
Level: 13 - 441 points to level up
so why does mine report a Vid of 1.35 if its the same damn CPU?
My komPuter - Mobo P35-DS3L rev2 CPU e6750@3.2GHz CPU Cooler: TRUE w/2xNF-SP12's RAM:2x1GB Ballistix@800 GPU:x1950pro GPU cooler :AC Accelero S1 Case: Antec 900 PS: Antec SP-500 Monitor:Samsung 931c
Old January 12, 2008, 09:18 PM
BALISTX's Avatar
What is reporting your Vcore of 1.35 the BIOS or CPU-Z?
[Heatware]
BALISTX.com
Old January 13, 2008, 03:02 AM
Not Vcore, Vid, the Voltage your cpu asks for, mine says "1.325V", yours says "1.200V", why I wonder?
  #19 (permalink)
Old January 13, 2008, 03:31 AM
BALISTX's Avatar
Well not all two chips are the exact same. There is a range of voltage that the CPU requires. To answer you question you'd have to contact Intel.
[Heatware]
BALISTX.com
  #20 (permalink)
Old January 13, 2008, 03:32 AM
fair enough, maybe they will trade me for a 9650...
Overclocking e2180 experiences Mr. Cipher Overclocking, Tweaking and Benchmarking 16 March 19, 2008 07:36 AM
temp. monitoring utilities and e2180 nikitos Overclocking, Tweaking and Benchmarking 18 January 15, 2008 02:12 PM
donimo's e2180 o/c log donimo Overclocking, Tweaking and Benchmarking 19 January 13, 2008 04:09 PM
Intel P4 3.0 Northwood Overclock enaberif Overclocking, Tweaking and Benchmarking 4 March 3, 2007 01:56 AM
