Old November 8, 2007, 12:34 PM
donimo's Avatar
Default Downsides to Gigabyte's "auto" overclocking?
Hi, I built this rig so I could play around with it more than a Dell/HP etc and recently thought I would try out the built in C.I.A. overclocking utility built into my P35-DS3L mobo.
It upped my e6750 from 2.66 to 3.26ghz, the RAM from 400 to 489.6 and the RAM voltage from 1.9 to 2.1.
Is this OK? it seems like a decent overclock, and all within the specs of my gear (OCZ gold rated to 2.1v in warranty).
I know I could go for more, but doing it this way allows it to ramp with load, it underclocks to 2.00ghz for internet stuff and then up to 3.3 for games etc, I kinda like that.
Just wanted to know what you all thought...
thanks!
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old November 8, 2007, 12:45 PM
thanks!
Never use software to overclock do some research and learn to do it properly.
Old November 8, 2007, 01:23 PM
donimo's Avatar
While that does give me your opinion, it doesn't give me much info.
It is right in the BIOS, so it is just as much a "hardware" overclock as anything else I might try, isn't it?
And if I do an "official" o/c it would run at that speed constantly, even though 90% of the time it would be surfing the internets. Whereas with this way it runs underclocked for that, and overclock for games.
I see this as BETTER than a traditional o/c until I can find info on why not, y'know?
I want this rig to last a long time, and a constant overclock will run hotter, therefore may have an impact on lifespan...
Old November 8, 2007, 01:30 PM
If your just surfing the net then don't bother overclocking.
You seem to have a few misconceptions too about overclocking. To get a proper overclock you need to turn off anything that downclocks the cpu and a overclocked cpu won't run hotter with proper cooling.
Old November 8, 2007, 01:43 PM
donimo's Avatar
My wife uses the PC 100% for facebook and hotmail, and she is on it quite a bit. I use it about 75% for gaming, but as I also have an xbox 360 and 3 other consoles my gaming is split up and the PC isnt my primary gaming machine.
Other things I use this PC for is encoding video and audio, 2 things that benifit greatly from o/cing the CPU.
I have o/c'd before but it was on a p3 1266, and with it running at 1400 it does get hotter, and "with proper cooling" implies that it does get hotter, requiring a better heatsink.
I just don't get the difference between letting the mobo do it and doing it yourself, and I LIKE the ability to auto-under/overclock based on load, its a good thing not a bad thing.
Old November 8, 2007, 01:50 PM
Not really. SpeedStep (E1ST) can be left enabled, it doesn't matter. Although I wouldn't use "Auto" features either and it's much more fun to tweak it by yourself!
The lifespan of a CPU is quite long, in fact, you'll have upgraded a few times before it dies under normal use.
Here's a pretty good guide:
Howto Guide: Overclocking C2D/C2Q Processors (v1.3)
Read guides here and there, study BIOS settings and you'll be overclocking in no time
Old November 8, 2007, 02:03 PM
donimo's Avatar
See, now "more fun" is a reason, and so far it is the only one I have.
it's almost enough too.
Old November 8, 2007, 03:25 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
The big downside to CIA is that it IS automated. By its very nature it will only be a mediocre OC. With a bit of tweaking and playing you could probably get a better OC by doing it yourself. Think of it like an Automatic transmission vs Manual. YES, the Auto will give you "good enough" but YOU can do much better when you can "feel" what it can take (and when to shift).
In my opinion CIA and its kind are good for people who want to say that they OC'ed their system but don't want to take the time to do it themselves. At the end of the day all that really matters is, is "good enough"....good enough FOR YOU. IF it is then CIA is OK...if not then its play time . Either way OC'ing (whether by you or by your comp) does technically void warranties....so why not have some fun and be able to justify the "risk" (which is minute...unless you blow up your system ).
Old November 8, 2007, 05:48 PM
sswilson's Avatar
I don't see anything wrong with using the bios "auto" overclock, but you are definately sacrificing some potential performance.
If you like the power saving features, then I'd say stick with it, but if you want full performance... have a look at what the auto OC does to settings and then start from there.
The only question I'd have is how fast the OC kicks in when gaming, and if that has much of an effect on gameplay.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old November 8, 2007, 06:22 PM
donimo's Avatar
Very true, with prime96 it kicks in right away and doesnt let off till you quit, but in a game that varies its cpu load it may get flaky if its up/down all the time...
When I tried my first game on it (star Wars, empire at war) I was dissapointed cause it ran pretty badly on 1920x1200 at full settings, kinda hoped it would be ok...
Overclocking "get together" [Ottawa] Wankerfx Off Topic 27 March 16, 2008 03:08 PM
"Reviewer Tryouts" Sandisk Cruzer Micro Titanium 4gb Masasuka Member Reviews 16 January 27, 2008 05:27 PM
"Reviewer Tryouts:" Logitech Cordless Desktop LX710 Review Scratch Member Reviews 9 November 22, 2007 10:17 PM
Circuit Shitty fires 3400 "overpaid" employees Babrbarossa Off Topic 0 March 29, 2007 07:41 AM
TweakTown reviews GeCube X1950 Pro Champion Edition with "TEC" cooling Supergrover Reviews & Articles from the Web 0 December 18, 2006 11:44 PM
