Old November 8, 2007, 06:38 PM
b1lk1's Avatar
X1950 Pro does not have the horsepower to push 1920X1200 with much over medium settings in most games.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old November 8, 2007, 06:47 PM
donimo's Avatar
yeah, I don't know why, but I just thought it would be enough, mostly due to it running on my x800xl, p4 520 system at 1280x1024 and full settings perfectly.
silly me
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old November 8, 2007, 07:26 PM
b1lk1's Avatar
Just turn down some of the settings. Right now, I am waiting for the piece that did not come with my HR03 allowing me to mount the cooler to my HD2900 so I am forced to run a 7600GS. I can play games @ 1920X1200, but at low-medium low settings with no AA/AF. Your card has some power, just not enough to use AA/AF.
Old November 9, 2007, 12:09 PM
donimo's Avatar
so is hi-res/low-settings better looking than lower-res/high-settings?
I will expirament, but I have to wait till tonight, maybe tommorow, so if your bored and know, otherwise no worries.
I knda thought it was something like that, cause the 1950pro can run brand new games pretty well still at high res in a lot of reviews so...
Old November 9, 2007, 06:27 PM
sswilson's Avatar
I doubt it'll run any of the "brand new" games at high res & settings, but it seems to do ok at Native LCD res with AA turned off.
Can't expect it to run something like Crysis maxed out when the game beats the crap out of the latest cards. :)
Old November 10, 2007, 11:10 AM
donimo's Avatar
I know, I just meant, better than 640.480...
Old November 10, 2007, 12:34 PM
Mr. Cipher's Avatar
I haven't used the CIA/RGB auto overclocking features on my Gigabyte motherboard, but I did play with the auto-voltage setting while overclocking my processor manually when I was reviewing the board (p35-ds3r). I found that the auto setting over-shot the voltage, giving the processor more juice than it needed. Not a bid deal in most cases...except that I was nearing 1.5v (max rated for my CPU) on auto, but could still run fine at lower voltages.
As I understand it, auto-overclock BIOS features make it easy to get 20%+ out of your system quickly if you don't have the time or ability to overclock on your own. But it sure feels good to say you did it yourself! Good luck
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Overclocking "get together" [Ottawa] Wankerfx Off Topic 27 March 16, 2008 03:08 PM
"Reviewer Tryouts" Sandisk Cruzer Micro Titanium 4gb Masasuka Member Reviews 16 January 27, 2008 05:27 PM
"Reviewer Tryouts:" Logitech Cordless Desktop LX710 Review Scratch Member Reviews 9 November 22, 2007 10:17 PM
Circuit Shitty fires 3400 "overpaid" employees Babrbarossa Off Topic 0 March 29, 2007 07:41 AM
TweakTown reviews GeCube X1950 Pro Champion Edition with "TEC" cooling Supergrover Reviews & Articles from the Web 0 December 18, 2006 11:44 PM
