Old May 8, 2010, 07:32 PM
gingerbee's Avatar
Default i7 voltage question
ok well i am have no problems i am just not sure if this is high i don't normally go for high overclocks just the easy one with low voltage.
But i am now running a little higher none of the voltage scare me at all i just need to know if this is ok
loadline is on
all on water on bench
@4.0ghz max temps 65-63-63-61
cpu vcore 1.275
qpi/vtt 1.26
Ioh core auto
dram 1.5
cpu/pll 1.8
@4.2ghz max temps 75-74-72-72
cpu vcore 1.34
qpi/vtt 1.3
Ioh core auto
dram 1.5
cpu/pll 1.88
now the only thing is the cpu/pll at 1.88 is a little high? could some of the more experience over-clockers tell me what they think
thanks for all your thoughts
Old May 9, 2010, 01:29 AM
you dont need pll that high
i'm stable @ 4.77 with 1.81v pll some blk settings i might raise it to 1.84
you other volts are nice
just keep it below 80c
only thing i have degraded a cpu with is pll so keep it down
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old May 9, 2010, 02:52 AM
gingerbee's Avatar
thanks that what i thought but i also thought that anything under 1.90 was ok will lower it. thanks a bunch
edit crappy thing is my board only goes from 1.7 to 1.8.
how much more nb voltage. kyle_L Overclocking, Tweaking and Benchmarking 17 May 24, 2009 06:31 PM
i7 voltage question gingerbee Overclocking, Tweaking and Benchmarking 12 March 9, 2009 11:04 AM
Voltage advice. encorp Overclocking, Tweaking and Benchmarking 3 November 20, 2008 11:49 PM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
Overclocking question (Voltage) Wasza Overclocking, Tweaking and Benchmarking 2 January 22, 2008 11:28 AM
