Old May 6, 2010, 04:31 PM
Patramix's Avatar
Default I5 750 OC, 1 core lagging?
got a question for you guys
ive just added 2 more sticks of ram for a total for 4x2gig, and while testing the ram, found out my OC became/or was not 100% stable.
so i redid the entire OC setup, i5 750, asus p7p55d-e pro, and some ripjaw f3
well not entire sure why yet, but i never could get the system 100% stable untill i started messing with all the voltages :
Blck : 200
multi : 19
ram : 1600mhz
cpu v : 1.3875v
IMC : 1.3v
ram : 1.5125(rated for 1.5)
PLL : 1.8625v
PCH : 1.1 (i think)
Max temps : 66C
untill i raised the imc/pll/pch to those lvl it never passed the 1.5 hour mark on prime without 1 of the cores getting an error. with those settings its been going on 3.5 hours (hoping it good this time)
but ive noticed something odd, ive never seen befor, Core 3 of the CPU is lagging behind the rest, its 4 minutes behind the 3 other cores (also noticed with all the testing that the core is 75-80% of the time the 1 that will get the error too). the other 3 cores are on test 10, while its on 7. runing a small TTF.
is it normal?
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Old May 6, 2010, 04:44 PM
headsh0t's Avatar
Had the same thing happen to me with a q9550. One core was unstable. You'll just have to find a speed, blck and voltage where the core becomes stable. It sucks to only have one core holding you back doesn't it? You could also take out 2 sticks of ram and try testing again and see if the core is still unstable.
Old May 6, 2010, 04:55 PM
Patramix's Avatar
its annoying to say the least. its not giving me any error's in prime so far thought witch i find weird, just seem's a bit slower then the other 3
been reading a bit more, got a few options i can try to play with, CPUZ is still showing me 1.312 on the core V.
gona let prime go for a few more and see what happens.
My Boinc Stats
[FS] Core i5 750 Quad Core System + 23" Asus LED Monitor + Logitech X-230 Speakers $1000 Yamcha Buy/Sell & Trade 7 March 14, 2010 10:18 AM
Core i5 750 vs Core 2 duo E8500 TheCoon CPU's and Motherboards 9 November 30, 2009 09:10 PM
Core 2 duo E6400 vs Core I5 750 Pidg76 CPU's and Motherboards 18 October 7, 2009 05:05 PM
