-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Will the XFX HD 5870 Reference Design OverVolt? (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/31672-will-xfx-hd-5870-reference-design-overvolt.html)
Kommandant986 May 3, 2010 12:39 PM
Will the reference design XFX HD 5870 overvolt? I want to know before I buy so I can O/C it and not have to pay for the XT/XXX version. The link is :NCIX.com - Buy XFX Radeon HD 5870 850MHZ 1GB GDDR5 4.8GHZ 2XDVI HDMI Display Port DIRECTX11 PCI-E Video Card - HD-587A-ZNF9 In Canada. . Thanks for your help in advance.
Delavan May 3, 2010 01:21 PM
Yes, the card you pointed out (ZNF9) overvolts by software, and is using Volterra voltage controllers.
BUT!!!!!!!! It's the one that is not in stock! I bought mine from NCIX a month ago and they had only 10 cards that sold within 24 hours and they never got more in. There is a waiting list at NCIX for people that want that card (reference design, volterra VRMs) They sell another one with the fan centered in the middle of the card (non-reference design) that doesn't overvolt (no Volterra there).
Kommandant986 May 3, 2010 02:49 PM
Thank you VERY VERY much. It doesn't matter. The stock they have doesn't matter as I will be waiting until the beginning of June to purchase my new rig anyways. Also, I will look at other retailers. Thanks again man! :canadianwave:
Chromey May 3, 2010 03:49 PM
So USed CCC for Over volt too?
Kommandant986 May 3, 2010 03:54 PM
I was planning to use MSI Afterburner.
