Old May 2, 2010, 10:46 PM
Default i5 750 stock cooler
Will the stock cooler be fine? I was told the stock cooler will run at 35 idle and I should be at 25, but I've also been told the stock cooler can OC to 3.3... so confused.
Note: My general question, will my CPU be fine with the stock cooler and no OC'ing.
Old May 2, 2010, 11:12 PM
clone63's Avatar
Wouldn't make much sense to ship a CPU with a cooler that can't cool it! It wont work unless there is some defect or anomaly occurring, such as:
-Defective cooler fan (too slow/doesn't work)
-Defective CPU
-Strange setup that prevents almost all air from flowing.
Upgrading the cooler is necessary if you decide to decently overclock or find the stock is too loud.
If you undervolt the stock speeds, it will run even cooler.
HOWEVER I think upgrading upgrading coolers can be one of the more fun things to alter with a pc, as it is very influential in expanding the limits of your performance, though it can be trying at times too.
Old May 2, 2010, 11:19 PM
-Defective CPU
Yeah I figured that there is no point in shipping a cooler that cant cool it properly at stock levels.. my friend is a jackass for telling me that one.
Thanks
Old May 3, 2010, 12:06 AM
clone63's Avatar
Well, there are probably different opinions on the matter, but I've run stock coolers on hotter chips, overclocked and still kept it going. Not too quietly mind you.
Old May 3, 2010, 04:54 AM
gingerbee's Avatar
intel/amd spend money to engineer there heats sinks it's not a guess. they will work fine for stock.
Old May 3, 2010, 08:23 AM
Fudd Rucker's Avatar
I was able to pull 3.33ghz (seemed to be a very easy sweet spot) on stock cooling on an i5 750 and an i7 860 without much temp issues. But these chips can take a brutal amount of heat before they start to act screwy.
I couldnt think of something snarky or interesting to put here this time around.
Old May 3, 2010, 09:14 AM
martin_metal_88's Avatar
You can get some little OC for sure but noise will be in the game. Personally I think that the 30$ price tag of a CM hyper 212+ is worth to get a far better OC with silence. Or you can point to the stock cooler a big and noisy fan like a delta 5000RPM. We have done this at job with the frist I7 we build and we get it at 3.8 with the stock cooler but it was hell of a noise.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old May 3, 2010, 10:21 AM
Alright thanks guys, I'll look into the CM hyper 212+
Overclocking I5 750 Behemoth- Overclocking, Tweaking and Benchmarking 2 March 15, 2010 06:43 PM
-bigadv on a I5-750 ??? MarkOne HardwareCanucks F@H Team 27 February 4, 2010 03:35 PM
Which is the best? 750 or 860 MarkOne Overclocking, Tweaking and Benchmarking 6 December 31, 2009 05:40 AM
i5 750 Build Help bumfloss New Builds 20 September 14, 2009 04:57 PM
