Old April 27, 2010, 09:48 AM
Default first time oc i7
here are my specs
ASUS Maximus III Extreme
Enermax Revolution 85+ 850W
4GB Patriot Viper II Sector 5 DDR3-2000
MSI R5850-PM2D1G-OC
i7-860
CM Hyper 212+
CM Storm Sniper BE
Right now my idle temps are around 21-26* and when i did prime95 it maxed at 39-42* under 100% load
3DMark06 score was 17788
this is all stock.
I am gonna start by following this guide
Core i7 Overclocking Guide For Beginners
but I am looking for some other tips or advice
Old April 27, 2010, 12:31 PM
Well I here's my first attemp and everything seems stable ran Prime95 for about 1.5 hrs
gonna leave it for today and go a little higher tomorrow
New 3DMark06 score is 20592
Old April 27, 2010, 01:04 PM
ZZLEE's Avatar
Default Nice temps
Do you have after market cooling installed ? Nice temps What are temps with full load ?
I perlonaly woud not go abuve 65 c at full prime load .
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 27, 2010, 01:41 PM
i have the hyper 212+ on the cpu. and the temps listed there was at full load 45 - 53. the Sniper Storm has great cooling with the 200 on top, 200 front, 200 side, 120 bottom and 120 out the back
Old April 27, 2010, 01:58 PM
ZZLEE's Avatar
Default I havent clocked an 1156
I have an i7 920 so I cant help more. Run it as is fore a wile to day to day stabilty. Fore use other than gaming or benching you can lower fan speeds if you want. I would use it at those clocks fore a wile and see if you like the preformance. As you overclocke further the games will begin to maintain stabillilty.
Post a Bios template and let the games begin if you want.
EDIT:
This post on EVga forums may give you a starting piont but each board and chip i7 870 so to speek requiers the use of differnt settings to get the best result. i7-860 and 4 RAM slots OC'ing WOOT STABLE
Look fore a forum post on your board and chip like this one to get information on your board.
Each time you change BIOS the game start all over
Old April 28, 2010, 09:49 AM
thanks for the ink
Old April 28, 2010, 10:34 AM
stoanee's Avatar
I like this thread also:
Guide to Overclocking the Core I7 920 or 930 to 4.0ghz - Overclock.net - Overclocking.net
heatware
Old April 28, 2010, 12:15 PM
these are the only settings i have played with so far btw
Ai Overclock Tuner - Manual
CPU Ratio Setting - Auto
Intel (R) SpeedStep (TM) Tech - Enabled
Intel (R) Turbo Mode Tech - disabled
BCLK Frequency - 160
PCIE Fequency - 100
DRAM Frequency - DDR3 - 1280MHz -
DRAM CAS# Latency - 8 DRAM Clock
DRAM RAS# to CAS# Delay - 8 DRAM Clock
DRAM RAS# PRE Time - 8 DRAM Clock
DRAM RAS# ACT Time - 24 DRAM Clock
CPU Voltage 1.10000v
CPU PLL Voltage - Auto
QPI/DRAM Voltage - Auto
IOH Voltage - Auto
IOH PCIE Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
DRAM Bus Voltage - 1.66v
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
DRAM DATA REF Voltage on CHC - Auto
DRAM CTRL REF Voltage on CHC - Auto
Load-Line Calibration - Enabled
CPU Differential Amplitude - Auto
CPU Clock Skew - Auto
CPU Spread Spectrum - Auto
IOH Clock Skew - Auto
PCIE Spread Spectrum - Auto
Old April 28, 2010, 02:21 PM
So from this point on should I increase the vcore first or just the bclk until it becomes unstable and then increase the vcore. or should i put the vcore at a safe setting first. I think 1.35v and the start increasing my bclk?
Old April 28, 2010, 03:20 PM
FATAL ERROR: Rounding was 0.5, expected less than 0.4
got this in prime 95. what does it mean. I tested the memory using memtest 4.0 and no errors reported
I would like to take the Time.... Soultribunal HardwareCanucks F@H Team 18 February 9, 2010 05:01 PM
Time for a New KB Signal2Noise Peripherals 9 November 15, 2009 01:21 AM
[WTB] blue ray movies ( will be updated with more from time to time) kyle_L Buy/Sell & Trade 3 September 2, 2009 04:20 AM
Ah...Time for a new 32' LCD TV :) jcmaz Display Units 23 May 19, 2009 10:58 AM
First time ocing help! Cadence Overclocking, Tweaking and Benchmarking 7 September 26, 2008 06:09 AM
