Originally Posted by S1RE The computer I want to overclock has these components :
asus p5b-e motherboard
nvidia 8800gts 320 mb vid card
dual core conroe processor
4 gb ram
Anybody have a similar rig and has overclocked safely? If so, could u possibly take a pic of your bios screen with all your settings so I can copy? If anyone has any advice or website to refer me to I would greatly appreciate it.  |
Firstly welcome to the forums.
Secondly don't be put off by these responses. The devil is in the details so they say. Like a doctor, the more info you give the better the prognosis or advice can be.
If you have cheap RAM it will have an adverse effect on your overclock. If you have a substandard PSU you won't be able to oc at all or if you do run the risk of frying your mobo or worse...
Every possible detail about your hardware that you can type, I would do so. At the same time it also helps if you yourself tell us what you have already researched and studied. As no one wants to do another persons research. Have a look around here as there are some links to some very good guides in these forums.
