Hey everyone, I got my new system (same as "Odin" in my sig) and decided to give overclocking a whirl. I currently have stock cooling, using an Antec 900 with all fans but the top one on medium - that one is on high. Components:
I booted the system with the F5 bios, and I was dismayed when I saw e2180 @ 1.8ghz (200x9). When I updated the bios, that fixed it. Also, the F5/F7D bios, without changing any values, had set my ram to the JEDEC standard for PC2-6400, which was 5-5-5-15 @ 1.8v. It wasn't until I updated to the F7D bios that I could change the timings. Later I learned that in the tweaking section of the bios, if you apparently press ctrl+F1 you open up a secret section. I never tried it with the F5 bios so I wouldn't know. Ambient - 20 Celsius, TJunction Max - 85 Celsius, all speeds CPU-Z verified and tested on Orthos. Stock voltage is 1.275v according to the bios. 1. Tried 210x10 on stock voltage, as a test 2. Upped it to 250mhzx10 = 2.5Ghz, no problem on stock. CPU-Z said the voltage under load went down from 1.232v to 1.216v (Any thoughts? verified) 3. Went to 280x10 = 2.8ghz, again 1.232v idle and 1.216v on load. (verified) 4. Went to 300mhzx10 = 3.0Ghz on stock voltage, loosened memory to 5-5-5-15, 2.1v to run at 900mhz. (verified) 5. Tried to go for my goal of 330x10 = 3.3Ghz, but at this point the system became unstable. I tried all minimum increments for the CPU voltage, and once I hit 1.375v without it being able to run Orthos (Super Pi 2M was OK) I resigned myself to 3.2ghz 6. 320mhzx10 = 3.2ghz at 1.375v. At this point I let the BIOS automatically set the voltage and that is the number it came up with. CPU-Z says I am idle-ing at 1.328v and on load, 1.316volts. My EasyTune (Gigabyte utility) says I am at 1.375 volts as I think it runs off the BIOS. Stable overclock for 8h52min Orthos. (Validated,screenshot) I just woke up so I haven't had time to aggregate and graph the raw temperature data. Eyeballing it, it appears that the temps went from 30/33 on idle @2.0ghz to 34/36 on idle @3.2ghz, to 54/55 load @2ghz to 62/63 on load @3.2ghz. Again, keep in mind that's with my Antec fans all on medium (except the top one on high), and stock CPU cooling. I would really like to push this to see if I can get to 3.4ghz but I'm worried about the kind of voltage I have to put through. I'll be installing my TRU 120 Extreme first to get some better temps. Something I also noticed was that despite having a 8800gtx, I can fit a fan in the side panel. Every review site I went to said that wouldn't work. Also, my cabling is really clean (as it can be) without any case mods, despite what everyone has said. I think I might review the case to show you all what I've done. Seeing as how I can put the fan on there, I may very well OC the gtx even more (again any pointers are appreciated). Lastly, seeing as how I have the heat pipe coolers on my RAM, I am going to try to overclock that...although it's hard to test without voiding my warranty. At least I can go to 2.2v. Oh and actually, one more thing. I have options such as increasing PCI-E frequency (I set this to 100 so it wouldn't go up on auto as I OC'D), FSB voltage and northbridge voltage. When would I change any of these settings? I was under the impression we simply give the CPU more juice and that'll get it to boot if we OC like mad. At any rate, if you have thoughts or suggestions, I would appreciate them very much. For now, I'm not going to complain about a 60% OC Time to go play some BioShock!**Update 1: I got up to 3.33GHz (333MHz x 10) last night at 1.425v. Stable for 8h30m with Orthos. I could boot at 1.306v at 3.33GHz, but it was not stable. I also installed my TR ultra 120 extreme, and temps are about 28/29 idle and 53/54 on load. It shaved a few degrees for sure, almost 8-10 on the load side and 3-4 on the idle side. It was HARD to install though, the amount of pressure I had to use to get my 2nd screw in, wow. Not fun. Works though. Now to try 3.4ghz. Any ideas what the maximum "safe" air cooled voltage might be, and when should/would I increase the northbridge voltage? What's the point of that? **Update 2: 3.4GHz (340MHz x 10) at 1,431v. Super PI 4m ran fine. Memory is 4-4-4-12, 850MHz, 2.1v. Testing with Orthos for the evening and will update tomorrow. Temps on 100% load reading 51/54 (~10c cooler than when I was at 3.2ghz w. no Thermalright Ultra 120 Extreme!), no throttling either. If the Tjunction max is 100C instead of 85C, my load is 65/69...seems high to me. Also noticed Rightmark reports the CPU as Allendale, CPU-Z reports as Conroe. **Updated 3: The previous OC was not stable - failed Orthos after 5h 23m. Upped voltage to 1.437v, and it's been stable for 9 hours now, memory at 4-4-4-12, 850mhz 2.1v. I am running Orthos for the rest of the day to continue testing for stability. It appears that I have gained 70% OC on my e2180, load temps still only 52/54. I wonder how much I've shortened its lifespan. Does anyone know if upping the FSB or NB voltage by +0.1v will allow me to drop my VCORE?
__________________ Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900. Intel E1xxx & E2xxx OC Thread Last edited by Mr. Cipher; November 7, 2007 at 07:45 AM. |
That's a great OC for the 2180
__________________ Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
I have been updating my post, but I'm not sure it notifies people that the thread has been added to, when I update my original post. So I thought I'd give myself a bump, 'cause I'm lame like that.
__________________ Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900. Intel E1xxx & E2xxx OC Thread Last edited by Mr. Cipher; November 5, 2007 at 11:02 PM. |
I was considering pushing on further to 3.6ghz on air, but I had a few questions that I was hoping the hwc community could help me with since I haven't found any answers online... 1. Is the performance jump from 3.4ghz to 3.6ghz worth the extra trouble and wear on my components? 2a. Does anyone know if upping the FSB or NB voltage by +0.1v will allow me to drop my VCORE? I don't want to go past 1.5v (at 1.437v currently) 2b. Other than obviously supplying more voltage, what does increasing FSB/NB voltage allow me to achieve that I couldn't otherwise? Similarly with PCI-E frequency (I have it locked to 100)?
__________________ Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900. Intel E1xxx & E2xxx OC Thread |
Cipher, nice OCing. I have just purchased a 2180 and want to do the same. I am new to OCing so don't see things going as smooth. One question I had after reading you write-up is how did you adjust your memory timings to 4-4-4-12? Are there setting inthe BIOS to set the timings? Oh one more thing, how did you flash the DS3R bios? TIA |
Sysco I just wrote you an email...sorry for the delay.
I too just got together a system with the e2180. I left the speed reducing stuff on in the BIOS so far, I know I know, but I wanted to see if I could retain it while getting a decent o/c. My results with an AC freezer 7 266x10 to 2.95x10 stk vltge - Boots fine runs 3dmark06, bioshock, TAT perfectly but orthos fails right away. 300+ x10 stk vltg-1.375v - wont boot Will try again with more common settings, I was really just satisfying some curisoties... Also you say your stock voltage is 1.275, but mine reports it at 1.325v, same chip, p35-ds3L mobo....
__________________ My komPuter - Mobo P35-DS3L rev2 CPU e6750@3.2GHz CPU Cooler: TRUE w/2xNF-SP12's RAM:2x1GB Ballistix@800 GPU:x1950pro GPU cooler :AC Accelero S1 Case: Antec 900 PS: Antec SP-500 Monitor:Samsung 931c |
Even identical systems won't get the same results. I didn't really do any stability tests at 1.275v, I only wanted to see if I could boot up and then I was going to push the voltage up by 1 notch increments until the system became stable. I read the voltage off from I set in the BIOS, rather than programs like CPU-Z - it fluctuates depending on what the processor is doing (I think it's called a vdroop, not sure?). 1.8 to 3.0 is still great however! My system runs Crysis on high detail at 1680x1050 without any problems whatsoever, I'm quite happy about it.
Are those figures Canadian? (jk) Seriously, I have a chance to pick up an E2180 (Retail) for about $61 US, because I am getting the bug to build another box. I am new to OC'ing tho, and found your write-up very interesting. I have no desire to "test the limits", but would like to get at least 3.0 out of this chip. Am I right in thinking I can OC the mobo and RAM also? (I know I can OC the GPU). Can you (or anyone) recommend a good Mobo to go with the e2180? I'll take RAM suggestions too. I want to get an SLI board so I can put twin 8800GT OCs on it, as my main game is Flight Sim (FSX). I will prolly stick with XP Pro for now but will eventually move to Vista (unsure about 32 or 64). I scored a sweet deal on a WD 640 Gb (twin 320 platters), but am also thinking of twin 150 Raptors in RAID 0. Any other suggestions would be greatly appreciated! netcop (from the land under you) |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/3136-overclocking-e2180-experiences.html | ||||
| Posted By | For | Type | Date | |
| Intel Pentium E2180 Retail Boxed $61.48 shipped after $20 off $80 GCO coupon - Page 3 - SlickDeals.net Forums | This thread | Refback | August 20, 2008 08:05 PM | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| BALISTX Intel E2180 Overclock | BALISTX | Overclocking, Tweaking and Benchmarking | 28 | February 25, 2008 12:39 AM |
| temp. monitoring utilities and e2180 | nikitos | Overclocking, Tweaking and Benchmarking | 18 | January 15, 2008 02:12 PM |
| donimo's e2180 o/c log | donimo | Overclocking, Tweaking and Benchmarking | 19 | January 13, 2008 04:09 PM |
| Overclocking P4 1.8 | Kassela | Overclocking, Tweaking and Benchmarking | 1 | December 27, 2007 12:28 PM |
| ThermalTake Armor 8003 experiences anyone? | S|nApSE | Cases | 12 | May 29, 2007 06:52 PM |
