Old October 31, 2007, 11:28 AM
Default Help, NEW PC Low Performance
My rig:
Core 2 duo e6550 2.33ghz
2gb Crucial xs at 4-4-4-12-2
P5n-e sli motherboard, 0505 bios
Sparkle 8600GT 512MB,
150gb 7200rpm seagate drive (80% free)/ external USB 2.0 180gb, 5% free)
SB Audigy
500w PSU
Downloaded what i think are the latest drivers..
I have tweaked the OS to have barely any services. I uninstalled my virus scanner.
Defragged the hard drive.
Turned off AA and the like...
Still getting 3200 on 3dmark, people with same system specs are getting almost twice that!?
I dont see any heating problems.. Any help is greatly appreciated, I REGISTERED TO POST ONCE!!!
Thanks again...
mew
Old October 31, 2007, 11:30 AM
What OS are you running? XP or Vista?
Old October 31, 2007, 11:56 AM
XP SP2
All updates
Old October 31, 2007, 12:59 PM
Moneyless's Avatar
If that is the 8600GT I think it is, it's 512MB of DDR2 RAM on it, which is slower then the GDDR3 (Obviously). Although I don't think it would lead to that much of a performance drop.
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old October 31, 2007, 01:04 PM
yes, it is.. and yes, i dont think THAT much of a perf drop... my confusion continues...
Old October 31, 2007, 01:32 PM
Shadowmeph's Avatar
Originally Posted by mewbomb View Post
My rig:
SB Audigy
500w PSU
Thanks again...
mew
xp, ok how many services are you running if it is tweaked as much as mine I have ( right now with Firefox peerguardian2, Sygate firewall,thunderbird email, clocktray skins and process explorer) I have a total of 20 process's when I am online gaming or testing I have at the highest 15 process's running so I would check your process's again
Old October 31, 2007, 01:33 PM
JD JD is offline
Try out the 0608 BIOS. I find it to be the best one.
Get the latest NVIDIA drivers direct from Welcome to NVIDIA - Graphics Cards, Motherboards, Notebooks, Desktop PCs
You want it for your graphics and chipset.
Otherwise, that's just how it performs. All the reviews I find are of the GDDR3 version and not the DDR2 version. From quick reading, it seems like the DDR2 version is alot slower than the GDDR3 version.
Old October 31, 2007, 03:24 PM
yea, how do i do that, i only see my chipset and graphics, how do i flash the bios, and where do i get it from?
Old October 31, 2007, 03:42 PM
Supergrover's Avatar
ASUSTeK Computer Inc.-Support-
Look to the left of the page it will explain how to update your bios.
If you have any questions just shoot.
R.I.P.
Old October 31, 2007, 04:16 PM
ok, how do i do this? should i do this???
Looks like my cpu isn't supported until this version!
OS gaming performance. Jim O/S's, Drivers & General Software 7 October 5, 2007 10:06 AM
500 Mhz more=how much more gaming performance?! bushwickbill Overclocking, Tweaking and Benchmarking 4 September 28, 2007 10:22 AM
-12v Rail and Poor Performance kcksteve Troubleshooting 11 September 9, 2007 08:08 PM
