Old April 8, 2010, 12:37 PM
AmuseMe's Avatar
Default Are two 8pin EPS really necessary?
Once Charles sends me the last of my parts, Ill finally be able to hook up this i7 and P55 FTW. I am aiming to get my i7 860 at at least 4GHz (if the chip isn't a POS batch) and am wondering if I really need two 8pin EPS cables plugged in.
I myself am thinking that I could only get away with one, as I have never seen or heard someone use both; two seems like overkill - can anyone confirm this?
Old April 8, 2010, 12:40 PM
3oh6's Avatar
Hardware Canucks Reviewer
a single one is absolutely all you need. the second one only comes into to play with massive loads and even with a Gulftown running wPrime over 5GHz on the ASUS R3E...a single EPS was just fine. HTH
Old April 8, 2010, 12:42 PM
CMetaphor's Avatar
Quadfather
... Or if you have a Quad-socket machine lol
1x 8-pin is more than enough.
Old April 8, 2010, 12:45 PM
AmuseMe's Avatar
Phew. that means I can just use my shorter 8pin cable. I was afraid I was needing to rout it somewhere (or just making a new one).
Thanks guys
Old April 8, 2010, 02:17 PM
MpG's Avatar
MpG MpG is offline
Just curious, Jodi - have you ever come across (or measured yourself) any meaningful differences in voltage drop between 1 and 2 EPS plugs? I was always under the impression that once you hit a certain speed, the extreme cooling required started to counteract the increase in current draw.
Old April 8, 2010, 02:31 PM
Voltage drop will be compensated for by the PSU's voltage regulation circuitry and the CPU's own VRMs.
Old April 8, 2010, 04:33 PM
one 8-pin gives what...150w? that should be enought least for the monstrous of overcolks
Old April 8, 2010, 05:39 PM
An EPS12V connector can supply much more than 150W.
Old April 8, 2010, 07:27 PM
MpG's Avatar
MpG MpG is offline
If you have LLC enabled, sure. But otherwise you're subject to the standard Vdroop - I was curious if the extra plug would have any influence at all on that area. I personally can't see the second plug making any difference for anything less than maybe a quad-socket board or something along those lines, but since my own overclocking doesn't go beyond the realm of single-CPU/watercooling, I'm hardly in a position to experience it for myself.
Old April 8, 2010, 08:13 PM
Vdroop and voltage drop are completely different things. Vdroop has nothing to do with the power being supplied to the board, and a second EPS12V connector won't make any difference to that.
ASUS P7P55D Pro & 8pin EATX12 with cap Logger CPU's and Motherboards 3 January 2, 2010 02:18 PM
[WTB] Seasonic 8pin & 6Pin PCI-E Overclocker~4.1 Buy/Sell & Trade 3 December 10, 2009 08:08 PM
Favorite TV Eps... omgwtf Off Topic 21 June 3, 2009 11:12 PM
Looking for extension cables - 24pin and 8pin MorePower New Builds 4 January 18, 2009 11:51 PM
4pin ATX12v and 8pin EPS connector magictorch Power Supplies 6 December 6, 2007 04:39 PM
