Originally Posted by 5ILVgeARX Damn, I am envious of you.
Can I ask some questions? Are you able to play multiple 1080p movies with DXVA? Lets say 2 HD clips as the same time. |
Originally Posted by Dr_BenD_over Sadly, I only have one 1080P 'clip' in my possession. |
Originally Posted by 5ILVgeARX Dang.
What about the video load under gpuz during playback?
Thanks again  |
Originally Posted by Dr_BenD_over Either I've got it configured wrong, or GPU usage is maxing out at about 13% while still using about 15% of the CPU.
I went by this: DXVA Support in MPC Home Cinema |
Originally Posted by 5ILVgeARX Thanks for sharing your findings :)
15% on CPU is kinda high, I think you just need to disable your external codecs on MPC-HC. I definitely believe those ati 5xxx will do a fine job
Thanks again
My results with a nvidia card  Even a 4350 have better results than nvidia's VP2  |
It would seem after years of NOT being able to get hardware video acceleration to work in any way, shape or form, it's WORKING! 1080P MKV, 1 to 2% CPU load, 2% GPU load. A screen cap @ 3360x1200 would be a tad excessive.
