<~----> EVGA's Votage tuner and Overvolting Help? - Hardware Canucks
Old March 26, 2010, 10:38 PM
Question EVGA's Votage tuner and Overvolting Help?
I have been trying to find my new Max OC. Recently I have found that If I don't put my Shader clock past 1404 and keep my Core at 702Mhz I can run my Mem clock all the way to 1260Mhz (2520Mhz Effective)
Now, When I open EVGA GPU Voltage tuner the voltage is always at 1038Mv, Even when Running it max load and at a high Overclock. And that is below the said "default voltage" of 1125Mv. So I really am only raising the volts to the supposed stock voltages?
So If I am only raising the voltage to the said "Stock Voltage" Am I really Overvolting my GPU? If Using 1125Mv is not consider Overvolting then maybe /I will keep it at 1125Mv to maintain higher OC's?
Can someone please shed some advice on raising the volts. I am only talking raising the volts to the default level as stated by EVGA Voltage tuner.
On the EVGA voltage tuner screen it says
Current Voltage: 1038Mv
Min Voltage: 825Mv
Max Voltage: 1288Mv
Default Voltage: 1125Mv?????
So by looking at that little chart I am trying to find my Max OC on a voltage that is under its' default voltage. So By me Raising the Volts to 1125Mv which is the supposed Default Voltage am I really Volt Modding my GPU?
System spec: Intel i7 2600k, Gigabyte GTX 570 Super Overclock, Kingston DDR3 2X4 GB sticks, ASUS P8P67 PRO, Cooler Master 700 watt PSU, 750GB*2 Sata,SATA III 1TB HDD Acer 24 Widescreen, Antec 300, Windows 7 Ultimate 64 Bit
EVGA Releases Precision 1.8.1 and GPU Voltage Tuner 1.1.2.2 FiXT Press Releases & Tech News 2 October 8, 2009 03:45 AM
EVGA GPU Voltage Tuner released burebista Video Cards 10 February 9, 2009 03:05 PM
Looking for a TV Tuner Zippoh Video Cards 1 January 29, 2009 03:55 PM
EVGA Voltage Tuner Coming! zlojack Video Cards 20 January 24, 2009 12:19 PM
scythe ultra kaze are BAD for overvolting!!! solaris10 Water Cooling 1 February 1, 2008 10:14 AM
