Old March 25, 2010, 04:40 PM
Uberg33k's Avatar
Restricted Poster
Default Before One Starts Benching...
What should be done/configured prior to running proggies like 3DMark06, Vantage and the like? I figured tweaking Windows, defragging but what else would the guru's here recommend?
Old March 25, 2010, 04:43 PM
ZZLEE's Avatar
Default Bios
Set fan speeds to 100%
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
gingerbee's Avatar
make sure there nothing running in the back round no pro it's just what i do before i benchmark.jmo
Old March 25, 2010, 04:46 PM
Uberg33k's Avatar
Restricted Poster
Making sure a fire extinguisher isn't far behind as well eh?
Old March 25, 2010, 04:52 PM
gingerbee's Avatar
^LOL good one not to forget ah
Old March 25, 2010, 04:54 PM
Good point from ZZLEE, fans on high for sure.
You can try running something like Game Booster, though I haven't found a whole pile, if any, difference.
If you run 3dMark06, you should be in the neighbourhood of 24K, with the setup you listed, OC on the cpu, gpu at it's stock OC.
A bunch less and something is screwing it up, and if it goes well over that, you're laughing.
Cold weather benching with water Dead Things Overclocking, Tweaking and Benchmarking 40 February 17, 2010 04:47 PM
benching 8800gtx jay51 Video Cards 17 September 26, 2008 06:29 PM
NoL's new Benching Cascade NoL Case Mods, Worklog & Gallery 16 July 29, 2008 07:30 AM
Some benching fun Eldonko Overclocking, Tweaking and Benchmarking 27 March 14, 2008 09:04 PM
Nvidia's DirectX 10, G83 starts at $69 Babrbarossa Press Releases & Tech News 2 January 26, 2007 11:16 AM
