Old March 25, 2010, 03:16 PM
Uberg33k's Avatar
Restricted Poster
Default Can't Get 5870 Vapor-X Passed 900MHz
I'm using MSI Afterburner because RiveTuner has no 5xxx support yet. No matter what AB won't let me go passed 900MHz. I go to set it to 950MHz for example and when I hit apply it goes back to 900MHz my current Overclock. I tried setting it to 901MHz even and no joy!
Is this a safety feature or something that can be turned off? Or am I missing something? Thanks in advance.
Old March 25, 2010, 03:57 PM
did you UNLOCK the overclock in the .ini ? (look into the MSI Afterburner folder, there's a .INI, and there's a setting that is =0 that read something like ForceOC or something. Put that to =1 and reload the software
(it's near the end of the file)
Old March 25, 2010, 04:04 PM
Uberg33k's Avatar
Restricted Poster
Yeah I just did. lol Thanks though. :D
Old April 4, 2010, 08:29 PM
Oversized Rooster's Avatar
Why aren't you overclocking with the Catalyst Center?
My Vapor-X can OC properly both the core and memory if I use CCC...
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old April 4, 2010, 08:41 PM
zc1 zc1 is offline
He's trying to go beyond 900 MHz, which is the max that CCC will allow for this card.
My Rig
ENGINE: i7-4770k on Z87X-UD5H // Zalman CNPS12X Heat Sink // 16 GB Vengeance DDR3-1600 MHz
ECU: Win 8 Pro, Kingston HyperX 120 GB SSD
FUEL PUMP: Corsair AX1200i
HUD: Asus GTX 690 w/ 3x Asus MX279H
CHASSIS: Silverstone FT02B-W
1/4 MILE TIME: ?
Old April 4, 2010, 10:24 PM
cozmosland's Avatar
ah then the only way would be either a modified firmware for the card or... there is a program, hopefully someone else knows the name that will let you set it farther but doing so will disable the power saving downclocking the card does at idle.
5870 Vapor-X, Dirt 2, Q6600, CFX vs Non-CFX zc1 Video Cards 2 March 20, 2010 08:41 PM
[FS] Sapphire 5870 Vapor-x, Rampage xtreme MB, Mushkin, pump, rad Mark Buy/Sell & Trade 28 January 9, 2010 07:34 AM
Sapphire HD 5870 Vapor-X 1GB Review Comment Thread SKYMTL Video Cards 24 November 9, 2009 02:50 PM
Sapphire reveals the HD 5870 Vapor-X Gav Press Releases & Tech News 7 October 27, 2009 11:50 AM
