Old March 14, 2010, 06:13 PM
Default Liquid nitrogen.. would this work?
I was just thinking.. instead of just pouring LN onto your cpu.. would it be more effective to pour the LN on and then attach it to a vacuum, forcing it to evaporate faster, and thus more cooling?
Old March 14, 2010, 06:32 PM
I think there's a point where adding more cooling capability would be pointless anyways.
Old March 14, 2010, 06:53 PM
Polygon's Avatar
probably.
Why would you need liquid nitrogen? Trying to beat the world record 3d mark score?
'Do not wish for easier lives, wish to be stronger men'
The Hobbit Thread
Old March 14, 2010, 06:55 PM
because it's cool!
hahahahhaha double entendre!!!
Old March 15, 2010, 10:28 AM
LarkStarr: try telling that to an extreme overclocker :p i bet if they could go int the negative kelvin they would :p
nickpolyz: no me per-say, but yes, that would basically be the reason :) (that and CPU-Z scores, and any other benchmark)
LarkStarr: damn straight! hehe
Old March 15, 2010, 10:46 AM
3oh6's Avatar
Hardware Canucks Reviewer
that completely depends on the chip and LarkStarr is right, for the most part, chips only operate in a range that doesn't tax LN2. Phenom II's can benefit from below -196C, and i'm not eve sure all of them can either as you run into cold board issues.
some Clarkbars have shown they can run below what LN2 can give them but only with low QPI, 90% of Bloomfield definitely can't -140C let alone colder, and Gulftown has shown no ability to max out LN2 before cold bug.
we are in a CPU age of temp control more so than all out lower temps...coming from an Intel bencher that is. AMD benchers might speak differently...but they are still slower anyway so who wants to listen to them ...yeah, i said it, what?
Old March 15, 2010, 12:15 PM
3oh6: wow, thanks! that's a lot of info ^.^ thanks for writing that up :)
and I see no problem with your last statement :p
Old March 15, 2010, 01:24 PM
dragoonxx's Avatar
3oh6 are you trying to egg CM on? doesn't he still hold the HWC record for fastest pi score?
Old March 15, 2010, 02:10 PM
please excuse me for talking about something I don't know too much about, but last i checked recently all the pi records are currently held by the i7 core. unless I've mistaken something >.>
Old March 15, 2010, 02:15 PM
dragoonxx's Avatar
the MP systems seem to be MIA from the lists, seems the current list is single socket only
TEC liquid cooling. Overclocker~4.1 Water Cooling 14 September 24, 2009 08:16 PM
anyone know of a Liquid acrylic filler? Shadowmeph O/S's, Drivers & General Software 3 June 6, 2009 11:18 AM
E2160 on liquid results. Wall86 Overclocking, Tweaking and Benchmarking 6 October 13, 2008 11:44 AM
...liquid metal instead of water! francois methot Water Cooling 15 July 20, 2008 03:17 PM
Fear of Liquid Cooling Beermaster Water Cooling 29 June 4, 2007 12:14 PM
