Old March 13, 2010, 09:28 PM
Exclamation EVGA GTX260 hitting 85-90C temps?
So I am not sure what has happened but all of a sudden my temps are a lot higher lately. And my card hits 85-88C During Furmark tests
So is that a safe temp to game at? i know I don't have to OC soo high. But I really need the extra performance I get in some games?
I don't leave it that those speeds all the time, Only during some games. So tell me what temp should i start to worry about? Because according this page;
http://www.nvidia.com/object/product...tx_260_us.html
Max temps are 105C
So I am still under that temp. But were should I start to back things down?
System spec: Intel i7 2600k, Gigabyte GTX 570 Super Overclock, Kingston DDR3 2X4 GB sticks, ASUS P8P67 PRO, Cooler Master 700 watt PSU, 750GB*2 Sata,SATA III 1TB HDD Acer 24 Widescreen, Antec 300, Windows 7 Ultimate 64 Bit
Old March 13, 2010, 09:34 PM
OHPC
Guest
Posts: n/a
What driver version?
Old March 13, 2010, 09:55 PM
seedvt's Avatar
Yeah, make sure you don't have the (now removed) latest driver version.
See: NVIDIA 196.75 Driver Recall - Overheating Problems Cause GPU Deaths
Old March 13, 2010, 10:27 PM
Arinoth's Avatar
Are you using EVGA Precision, if so what is your fan setting set to, please tell me not auto (which is typically about 30%)
Old March 13, 2010, 11:37 PM
+1 for above. either drivers or precision keeping it at ridiculously low rpms unles it hits crazy temps
Old March 14, 2010, 06:33 AM
martin_metal_88's Avatar
If your card get's hot in furemark then it's normal the software have been made for THAT! just be sure she never passe 85-87 when you are long time gaming and you will be safe.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old March 14, 2010, 09:05 AM
I keep my card in the 70s and low 80s. Try firing up Precision, setting your fan speed to somewhere between 60 and 80%, and see what kind of improvement you get from that.
Old March 14, 2010, 12:26 PM
Yes, don't leave your fan setting on "Auto." When I run Furmark, I always set the fan setting to 100% because it really stresses your video card.
Old March 14, 2010, 12:42 PM
ZZLEE's Avatar
Default 2 settings
Set a setting at 45-50 % in preesision use that when your not GAMING
Set a setting at 75-80 % as loud as you can stand fore GAMING
Go into BIOS and see if you have a a fan control opions set your case fans to 50% all the time and if temp goes over 60 degreees celcius 100%
100% If no one in your house complaines
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
evga or XFX gtx260 core 216 kromesta Video Cards 14 August 6, 2009 10:35 PM
EVGA gtx260+ or XFX gtx260 Black Edition Kyure Video Cards 20 February 12, 2009 11:39 AM
[FS] EVGA GTX260 Superclocked+ @ $250 kenken3686 Buy/Sell & Trade 7 December 14, 2008 09:38 PM
FS: EVGA GTX260 - EVGA 750i FTW kenken3686 Buy/Sell & Trade 2 October 2, 2008 07:28 PM
eVGA GTX260 Superclocked + ehh? freakgeek1337 Video Cards 3 September 1, 2008 04:35 PM
