Old March 11, 2010, 02:17 PM
Default Help on new OC
Hi all, I'm sorta new to overclocking, but bought a mobo and cpu off a user on here and it was pre-oc'ed
The mobo is:
Gigabyte GA-MA78GM-S2H
and cpu:
AMD Athlon II X2 240
Now, I've put in ram that didn't come from this seller, it's G-Skill DDR2 800's
So I'm wondering if there is anything wrong with this setup, here is what is in the bios
Code:
CPU Clock Ratio x14
CPU NorthBridge Freq x7
CPU Frequency 275
PCIE CLock 101
HT Link Width Auto
HT Link Frequency 1.4 ghz
Memory Clock x2.66 [732mhz]
CPU NB VID COntrol +0.175V [1.35v]
CPU Voltage Control +0.100V [1.520v]
Normal CPU Vcore 1.425V
I don't really understand the Memory Clock x2.66 part, is my memory being overclocked?
From what I've read, based on the processor clock (3850mhz) and the divider (with is the northbridge freq? - 7x) I'd think that my ram needs to run at 550mhz.
I've been trying to read everything, but can't piece together which terms are which.
Any help/input/knowledge would be much appreciated!
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
Old March 11, 2010, 02:22 PM
SugarJ's Avatar
Your memory will run at up to 800 mhz without overclocking. The 2.66 part is the memory multiplier. See if it's adjustable to 3.0, that would run your ram at DDR2-825, which they should be capable of.
Old March 11, 2010, 02:37 PM
Thanks for your input, how does the divider fit into all this?
