Old October 19, 2007, 05:28 PM
mattydies's Avatar
Default Quick Simple question
I bought a used E6600. there seems to be a "spot" on the bottom "pins"
Im sure it will easily clean off. I do not want to damage the chip. Can I use Alcohol and a Lint free cloth?
OR ?????
Thanks, and sorry for posting here, but I JUST Got the chip and am eagar to install. This area seemed to have the most viewers lol.. :)
Matty
Old October 19, 2007, 05:34 PM
Misoprostol
Guest
Posts: n/a
you can try that, but I'd need to see a picture to be more sure...
Old October 19, 2007, 05:36 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeah just wipe it clean
Old October 19, 2007, 06:44 PM
mattydies's Avatar
1 wipe = clean.
The Quick and Dirty OC. BALISTX Overclocking, Tweaking and Benchmarking 5 March 3, 2008 12:55 AM
Quick Question. Khronos Display Units 2 January 7, 2008 01:16 PM
Who is using nTunes and is there something better thats simple? Canadianguy Video Cards 4 December 3, 2007 07:14 AM
Intel 775 Heat Sink - QUICK question mattydies Water Cooling 3 June 26, 2007 06:57 PM
IBM doubles CPU cooling capabilities with simple manufacturing change Babrbarossa Press Releases & Tech News 3 March 27, 2007 08:36 AM
