Old March 6, 2010, 09:58 AM
Fudd Rucker's Avatar
Default Ram wont overclock
Got my tech station yesterday, tear down from my lancool and threw it all in the tech station went great. Only problem im having now is this
Previously my ram ran @ 2ghz with zero issues since the day I got it, and MAC also had it @ 2ghz(this is a review board he did a review on)
Since the system was put in the tech station my ram wont run past 1600mhz. No matter what amount of voltage i throw at it my ram absolutly will not run 2ghz.
Any suggested to why this would happen? I comepetely baffled to what is going on as a case change should have zero impact on how my system performs other than heat.
I couldnt think of something snarky or interesting to put here this time around.
Old March 6, 2010, 12:01 PM
martin_metal_88's Avatar
Well from crucial I am not surprised at all..most of the time once she run fine she wont run like this another time. If she can't do aat the same setting she was previously there is nothing more to do. She will probably die soon. You can try to put your techStation in vertical position mabe your memory dislike to be other way XD
Old March 6, 2010, 01:02 PM
BigDogg's Avatar
Maybe check the ram for errors using Memtest.. That might give you and indication if the ram has bone bad..
Old March 6, 2010, 02:31 PM
try overclocking with just one stick at a time? (assuming you're using multiple sticks, of course.)
Old March 6, 2010, 02:37 PM
Make sure its running at proper voltage and possible bios update.
Old March 6, 2010, 03:56 PM
Whats really bothering me is that there was literally zero hardware configuration change other then case. I kept everything intact pretty much when I transferred it from point A to point B. Doesnt make sense that with literally zero hardware changes that an overclock would just stop holding. Only upside to this is that I brought my voltage down 1.55v and the timings @ 7-7-7-20 1T 1600mhz vs 9-9-9-24 1T 2000mhz 1.68v.
I even loaded my saved bios settings to what I knew for a fact was a rock stable 24 hour linpack overclock of 3.8ghz/2ghz memory and it wouldnt load anymore either. Mighty odd I tell you.
Old March 6, 2010, 04:00 PM
sswilson's Avatar
The only difference between a traditional case and a techstation would be airflow over the memory. It could be that the higher voltages required for 2G need some form of active airflow to wick away the extra heat. Did you try using a fan directed at the memory?
Old March 6, 2010, 04:10 PM
I have 2 flex 1600rpm fans attached to my radiator on the top of the board. Love how this had mounts for 2 x 120mm fans togeher for simple radiator installation. Temps have dropped signfigantly due to open concept, better oreintatio of the watercooling loop.Just one of those odd things I guess, thinking I might just throw a pair of 4gb sticks with my current setup for 12gb of ram total and be happy with 1333mhz with wicked tight timings.
Help Me Overclock My Ram bkh2 Overclocking, Tweaking and Benchmarking 7 February 15, 2010 01:47 PM
Overclock on RAM quikgp RAM 6 December 12, 2009 12:59 PM
Ram overclock and Boinc matsta31 HardwareCanucks F@H Team 3 October 6, 2008 07:38 AM
ram overclock Tazer-[X] RAM 13 August 3, 2008 09:54 AM
How does this ram overclock? klaiboi RAM 7 March 23, 2008 05:42 PM
