Old March 4, 2010, 01:31 AM
Exclamation Rivatuner settings? Help
I was looking under the plugins sections and noticed the VT1103.dll sensor. Now when I have it (plugin VT1103.dll) enabled under the hardware monitoring app on rivatuner, The temps are diff then the ones that EVGA precision is displaying??
Right now while doing a Artifact scan, EVGA precision is showing a temp of 70C, And under Rivatuner
VRM phase 1 temperature, C = 55
VRM phase 2 temperature, C = 56
VRM phase 3 temperature, C =57
So which one of these temps would be the best one to go by?? Because I am trying to find a new high OC after installing Win 7 ultimate 64 and I really need a accurate temp of my GPU! I will be adding voltage VIA EVGA voltage tuner also, So it is critical that I have valid temps of my GPU!
So can someone please help me understand which temp to go by?
Or is there a better way to monitor my GPU temps?
Here is the description in Rivatuner of the plugin in question, It clearly states that it is for the GTX200 Series!
"This plugin provides Voltage regulator output, Voltage regulator temperature and Voltage regulator current hardware monitoring data sources for display adapters with Volterra VT1103/VT1105/VT1165 voltage regulators.
Tip:
VT1103/VT1105/VT1165 voltage regulators are used on reference design ATI RADEON X1800, X1900, HD 3800, HD 4800 and NVIDIA GeForce GTX 200 series display adapters."
System spec: Intel i7 2600k, Gigabyte GTX 570 Super Overclock, Kingston DDR3 2X4 GB sticks, ASUS P8P67 PRO, Cooler Master 700 watt PSU, 750GB*2 Sata,SATA III 1TB HDD Acer 24 Widescreen, Antec 300, Windows 7 Ultimate 64 Bit
Old March 4, 2010, 01:39 AM
burebista's Avatar
70C in Precision is for what? GPU? VRM's? PCB?
What do you see in GPU-Z?
If it ain't broke... fix it until it is.
Old March 4, 2010, 06:24 PM
That 70C in precision was GPU temp. But yeah I just remembered GPU-Z and am going to be doin some testing tonight?
Nobody trusts Rivatuners plugin that is supposed to be for GTX 200 series?
Old March 4, 2010, 10:25 PM
burebista's Avatar
I trust it.
GTX280 - RivaTuner. Gellidius Troubleshooting 5 November 11, 2009 07:55 AM
RivaTuner 2.10 is out! 1Tanker Video Cards 19 September 7, 2008 02:09 PM
RivaTuner for SLI RussianRedScorpion Video Cards 7 April 23, 2008 08:15 AM
RivaTuner 2.07 realeased! Babrbarossa Video Cards 13 March 5, 2008 11:43 AM
new rivatuner v2.03 ragenrok Overclocking, Tweaking and Benchmarking 2 August 29, 2007 11:05 AM
