Old February 17, 2010, 02:59 PM
MarcusFoX's Avatar
Default Q9550 4.207ghz/ Maximus II Formula
Hey guys some clocks ive been working on over the last week which 24/7 stable of course I dont believe in anything else. Ive been able to get 495 working on 500fsb this week.
some one on here really has to start a S775 s1366/s1156 OCing sticky so Canadians like myself can compare my overclocks with my fellow countrymen.
Hardware:
Q9550 E0 Stepper
Asus Maximus II Formula 2202 Bios
4gb 2x2gb Mushkin Enhanced 996599.
Corsair hx850 psu
hope everyone enjoys
Vcore: 1.47
vtt:1.7
NB:1.65
Gtl's
memory Read:lighter
TRD:9-11
0:-10
1:-55
2:-10
3:-55
A+ NET+ Linux+ LPIC-1 MCP MCTS MCSA MCITP
World of Tanks WGLNA
CSGO ESEA
Heatware: MarcusFoX
Old February 17, 2010, 03:08 PM
quite nice.
I can't get my maximus I past 450fsb without it exploding.
I could post it's setting later on..
also, that's a hot vtt!
Old February 17, 2010, 03:17 PM
I hope you realise that your Vcore is way above safe levels. If you don't care about the longevity of your CPU, then that's a pretty nice overclock.
Old February 17, 2010, 03:55 PM
Dead Things's Avatar
I'm most impressed by how far you've managed to push that RAM! Nice!
Okay - I admit, I'm most impressed by the desktop image. I'm second-most impressed about the RAM!
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old February 17, 2010, 05:00 PM
Perineum's Avatar
MmmmMmmmMmMmm flowers.
Old February 17, 2010, 06:52 PM
geokilla's Avatar
It's not way above... max should be 1.45Vcore. He has it at around that. I'm more concerned about his VTT and NB volts. Oh don't forget the temperatures too..
How's system stability?
Old February 17, 2010, 06:57 PM
The maximum is 1.4V if you take into consideration the 50mV voltage overshoot specification.
Old February 17, 2010, 07:22 PM
50mV overshoot?
I know the vtt and nb overshoot a little, but not the core.. (at least not much on mine) and you have to consider the droop as well (though the droop is excellent on the maximus')
Old February 17, 2010, 07:48 PM
Droop isn't really a concern because you don't have to worry about the voltage going too low (outside of stability issues, but at least that won't harm the CPU).
Old February 17, 2010, 09:46 PM
MarcusFoX's Avatar
The vtt was set at this only because these boards are so stubbern with 500fsb... as soon as you get close to the magic 500 the board hit a wall and becomes very unstable with a quad... memory also plays a large roll in this, I also seemed to get better resaults with 2202 bios and a 5:6 dram:fsb ratio idk if this a sweet spot but it worked for me.
only thing that was really a pain was setting the gtl's and understanding the logic around it once that was set every fsb clock from 472 all the way to 500fsb became stable will alittle vtt voltage.
temps are in the 80's but there not to abnormal for a quad at 4.2ghz on air cooling at 100% load. My I7 was always in the 90's under prime at 4.418ghz I only had the vcore at 1.3875v and it never died on me it still kickin in my brother system at the same settings.
The for sure voltage I know that is proven to fry cpu is pll over 2v.
CSGO ESEA
Heatware: MarcusFoX
Maximus III formula BobbyLou CPU's and Motherboards 2 November 18, 2009 04:04 PM
Striker II Formula or Maximus Formula II trayton CPU's and Motherboards 1 August 30, 2009 03:04 PM
WTB Maximus Formula SE MarcusFoX Buy/Sell & Trade 10 July 16, 2008 02:47 PM
maximus formula shortestraw RAM 7 April 29, 2008 08:56 AM
Maximus Formula RAID? JD CPU's and Motherboards 9 January 16, 2008 08:20 PM
