Old October 14, 2007, 11:28 AM
Default lapped e6600
So I decided to see if this was worth all the fuss and haven't really notice much improvement in all honesty.
My e6600 is overclocked to 3.4ghz @ 1.47v and idle its around 47 degrees with the Tuniq and under load hits around 60 degrees. Hard to say if its anything else causing some problems like possibly my Tuniq fan needs to be replaced but anyways heres the pics.
Just as a side note there was some spots around the outside edge I couldn't get and since I didn't know how far down I could go I didn't want to rish the chance of cracking or destroying the cpu so I left it.
Start
Getting there
OOOOH pretty copper
Almost there!
Finished!
Old October 14, 2007, 12:16 PM
Babrbarossa's Avatar
Lee Valley has some good lapping accessories for that smooth polish -considering ordering some myself for messing around with - also good for flattening my waterstones and planer heads
Old October 14, 2007, 06:01 PM
Wasn't going for polished just lapped :) And even with a fan spinning at 2000rpm the temps aren't any better than if I hadn't of done it.
So I'm probably gonna drop the tuniq and upgrade to the ultra 120 and see what happens.
Old October 14, 2007, 06:05 PM
sswilson's Avatar
Did you try lapping the tuniq? Could be the surface of its base was the original weak link.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old October 14, 2007, 06:17 PM
Tuniq has a pretty flat base already but between the heatpipes and the base theres probably 1/8" of material but either way I am around 60 degrees underload which is good.
I'm just curious how much difference the Ultra120 would make.
Old October 14, 2007, 08:04 PM
not worth the upgrade
Old October 15, 2007, 02:05 PM
Theblackmages's Avatar
hmmm might do it for my E2140 and AC freezer 7 pro... i do have a bit of experience in sanding too... I'll do it if I'll need better temps.Some say if you do it right you can drop your temps 5C's. also I'm wondering, when you've finished lapping them, do you really need to put some thermal conpound at all or less or same since the contact between the HSF/CPU is way better?
Old October 15, 2007, 02:17 PM
Supergrover's Avatar
Yes you do still need TIM, the TIM fills the tiny, tiny imperfections in the surfacearea, lapping smooths the surface making it far easier for your TIM to do it's job.
R.I.P.
Old October 15, 2007, 02:29 PM
Cptn Vortex's Avatar
Theblackmages, I love your avatar. Zero hour ftw!
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.2GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old October 15, 2007, 02:32 PM
Eldonko's Avatar
Hardware Canucks Reviewer
GJ, what difference in temps did you get?
Lapping my E6600 CanadaRox Case Mods, Worklog & Gallery 19 March 10, 2008 09:03 AM
FS - Q6600 Lapped, E8400, 4 GB ReaperX PC28000, 8800 GTX zlojack Buy/Sell & Trade 39 March 5, 2008 08:14 PM
AM2 4200 vs. e6600? ragenrok CPU's and Motherboards 28 May 4, 2007 03:14 PM
e6600 p5b help plz... razor4life CPU's and Motherboards 14 April 7, 2007 12:32 AM
