Old October 15, 2007, 02:49 PM
Theblackmages's Avatar
Originally Posted by Cptn Vortex View Post
Theblackmages, I love your avatar. Zero hour ftw!
hehe thanks, SCUD STORM! lol.
thanks supergrover.So from what im understanding with lapping the tiny gaps are tinyer which makes it better... hmmm....
Old October 15, 2007, 06:20 PM
Supergrover's Avatar
lol That was bad wasn't it?
By making it flatter you have better contact with in this case the heatsink, TIM expands and contracts when heated and cooled, "curing" filling any imperfections in the surface area, you want the closest contact between the two surfaces and the best finish "smoothness" you can.
R.I.P.
Old October 15, 2007, 06:25 PM
b1lk1's Avatar
No offense, but what you did to that CPU is not considered lapping. If it was lapped properly, you would see your reflection in it. What you did is not going to help temps much if at all and you really need to get a smooth finish on that CPU.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old October 15, 2007, 06:58 PM
Actually your somewhat incorrect.
While giving it a mirror finish is probably a better thing the main reason for lapping a cpu is to get rid of the inperfections in the surface. A lot of cpus are not perfectly flat from the factory and doing what I did removes that.
Old October 15, 2007, 07:10 PM
yup that's lapped , he just didnt polish it which gives the mirror finish.but did you just sand with 1 sand paper or did you start with a lower grit and work yourself up to a higher grit?
Old October 15, 2007, 07:20 PM
Only done with 150 grit paper I know I could do more if I wanted and I may but not for a bit.
Old October 15, 2007, 07:30 PM
thats what i thought, its probably worse that it was before.... lol.get some other sand paper. go get some 300 , 500, 800, 1000 , 2000 and stuff lol.
or just follow a tutorial next time :P . also lol @ you... hahaha...
Old October 15, 2007, 08:24 PM
I don't need tutorials I know how to do it I just got lazy and wanted to flatten it. I'll worry about the other grits later. It idles around 46' and never hits over 60' under load so *shrug*
Lapping my E6600 CanadaRox Case Mods, Worklog & Gallery 19 March 10, 2008 09:03 AM
FS - Q6600 Lapped, E8400, 4 GB ReaperX PC28000, 8800 GTX zlojack Buy/Sell & Trade 39 March 5, 2008 08:14 PM
AM2 4200 vs. e6600? ragenrok CPU's and Motherboards 28 May 4, 2007 03:14 PM
e6600 p5b help plz... razor4life CPU's and Motherboards 14 April 7, 2007 12:32 AM
