Old February 15, 2010, 04:34 PM
Default Stable OC?
After how many hours of Prime95 SmallFFT can I call it a day? Been going right now for 5 hours no problem.
i7 920 @ 3.8 GHz
Old February 15, 2010, 04:43 PM
gingerbee's Avatar
with prime95 everyone says a little different. I run it for 8 hours but that's just me. most i think would say your good but lets see ah. or just run occt for 30 mins i have found this works well think i stole this from charlie3.0
Old February 15, 2010, 04:47 PM
MarkOne's Avatar
I don't know why people run test so long. I do 1 hour only, anyway it's always the time to came back to test if the PC crash no ?
Old February 15, 2010, 04:56 PM
Gonna give 30 mins of OCCT a go. Thx.
Old February 15, 2010, 05:32 PM
At least 20 runs of IntelBurnTest or whichever flavour of Linpack you prefer is usually sufficient to check stability. However, no matter what stress test you use, it's still possible that there is an application out there that will prove your overclock to be unstable.
Personally, I use IntelBurnTest to quickly check an overclock, but I find Folding@Home to be the best test of long-term reliability .
Old February 15, 2010, 05:36 PM
geokilla's Avatar
I like OCCT more than Prime95 as it stresses the computer more and takes less time. I usually spend anywhere from 2 to 5 hours of OCCT testing then call it a day if it passes. I hate Linpack. Un-needed stress testing program imo.
Old February 15, 2010, 07:04 PM
mix it with winrar large files, 3dmark looping. fah. if it doesnt fail youre good.
Old February 15, 2010, 08:33 PM
MonsterSound's Avatar
I agree with the others about mixing it up. IntelBurn will quickly let you know if your in the ballpark, but even with many hours of Prime95 passed, another app can fail. Like folding a -bigadv at 93% (ouch! that one hurt).
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / Windforce 7970 / MSI Z77A-G45 / 8gb G.Skill 2133 1T / ASUS 25.5" / Antec P280 / PCP&C 950 / Intel 520 SSD 2400gb / Eclipse / G3-Lazer / YSM1 / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old February 15, 2010, 08:39 PM
Well it passed 2 hours of OCCT and 5 hours of Prime95, seems good for now!
Thanks for the input guys!
Old February 15, 2010, 10:50 PM
ya, that's probably stable enough.
Stable OC no longer stable? Arinoth Overclocking, Tweaking and Benchmarking 17 December 1, 2009 08:00 PM
Router not stable JMCD Networking 16 April 2, 2009 10:33 PM
[FS] QX9650 4.1 Stable matsta31 Buy/Sell & Trade 5 November 21, 2008 05:56 PM
For you, what constitutes as 'stable'? chouchou Overclocking, Tweaking and Benchmarking 18 November 19, 2008 09:37 AM
OCCT Stable 1/2 Scratch Overclocking, Tweaking and Benchmarking 5 April 13, 2007 03:29 AM
