Old February 15, 2010, 08:10 AM
r0k0's Avatar
Default Thermal Paste
Hey Dudes and Dudettes
Just want to informe you guys about Innovation Cooling 24Carrat Diamond Thermal Paste
i've bought it for the shits and giggles on NCIX,com and i've put it on my GTX 260
With OEM Paste and Heat Pads
under idle my GTX 260 GPU was average 45-46*C and PCB 38-39*C and under Gaming GPU 70-72*C and PCB 45-47*C ( With 40% Fans on Idle and Gaming )
Now with the IC 24Carrat Diamond Thermal Paste
under idle my GTX 260 GPU is average 36-37*C and PCB 31-32*C and under Gaming GPU 59-60*C and PCB 39-40*C ( With 40% Fans )
Now this Thermal Paste Is The lol
So if you are willing to Upgrade Thermal Paste.. Dig out 30$ For it on NCIX.com its Worth it..!
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old February 15, 2010, 08:40 AM
MarkOne's Avatar
not that I want make loose a sell to NCIX but they have it here in the HwC store
https://store.hardwarecanucks.com/pr...-Compound.html
Old February 15, 2010, 01:46 PM
r0k0's Avatar
i didnt know they had..! cool to know if i run out :)
Main Rig
Canadian Eh ?
Old February 15, 2010, 02:17 PM
Spikemaul's Avatar
I just did my 275SC and got abouy 8C difference in load temps while folding. I'm going to take it apart this weekend again just too see what kind of coverage I got on the chip.
Old February 15, 2010, 02:45 PM
Lpfan4ever's Avatar
Yeah, the IC7 (which is just a smaller tube of IC24) I put on my GTX260 before it got whored around the BST here was amazing, I got over 10C off from load temps. It shows you that both IC7 is amazing, and that the stock stuff is horrible.
Originally Posted by encorp
Code:
<firebane> slightly used
Old February 15, 2010, 03:42 PM
headsh0t's Avatar
How many applications do you get with that?
Old February 15, 2010, 03:56 PM
ZZLEE's Avatar
Default 5 cc
the recomended aplication in 1 pea sized blob. So 4 or 5 to the 7 caret and 18 to 20 fore the 24 caret.
EDIT:
1.5 g fore 7
4.5 g fore 24
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 15, 2010, 03:58 PM
MarkOne's Avatar
a pea look to much for me.. all true I have not try the IC7 yet
Old February 15, 2010, 04:00 PM
A pea-sized drop is way too much paste. You should only need about as much as the size of a rice grain.
Old February 15, 2010, 04:02 PM
MarkOne's Avatar
and an uncook grain of rice
Thermal Paste? Luckk Air Cooling 16 November 24, 2009 07:57 PM
Thermal Paste question CV2010 New Builds 13 October 14, 2009 10:46 PM
Thermal Paste miggs78 Water Cooling 4 September 10, 2009 07:17 PM
Reapplying thermal paste? ricknash61 Overclocking, Tweaking and Benchmarking 4 September 5, 2008 12:17 PM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 05:43 PM
