Old February 10, 2010, 06:42 PM
r0k0's Avatar
Default eVGA Precision 1.9.1
Ever Since i installed Win7 Ultimate x64
under eVGA Precision i cannot see my GPU Temps anymore..
Anybody know why..?
And i've looked in the Option menu and Monitoring Tab and its just not there..! on the eVGA site it says there the In-App GPU Temps monitoring.. but i cant see it!
Thanks
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old February 10, 2010, 06:48 PM
lowfat's Avatar
Do you mean in the Precision window? Or in the system tray? or OSD? You need to be more specific.
Old February 10, 2010, 06:50 PM
ZZLEE's Avatar
Default Temp
Click the rench icon next to the apply button. Click on monitoring. check in box GPU temp. The graph should appeare . :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 10, 2010, 06:54 PM
rjbarker's Avatar
If your using Precision 1.9.1 (latest version), their are reported "issues" when paired with GeForce 196.21 WHQL or earlier.
Either try the latest Beta Driver 196.38 (been working flawlessly for me) or use the previous version of Precision.
Everything you need to know about Precision here:
EVGA Precision
Hey ZZ....glad to see your using my "quote".....too funny!
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old February 10, 2010, 07:10 PM
r0k0's Avatar
like i've said... it is not in the Monitoring Tab... im using the most recent.. i've had 190.x.x and up on Win7 and its hasnt showed up.. and i used 190.x.x on Vista 32bit with 1.9.0 of eVGA Precision
i also tryed 1.8.1 and still not there..
Main Rig
Canadian Eh ?
Old February 10, 2010, 07:15 PM
rjbarker's Avatar
What Driver are you using?( Be specific, no 19x.xx)
Have you tried a Clean Install of Precision?
Try and be more specific of exactly what you're not seeing, from what I understand your NOT seeing the "GPU Temps" in the "Monitoring Tab"..is this correct?
Do the Core Clock, Memory Clock, Shader Clock and Framerates appear?
Old February 10, 2010, 07:31 PM
r0k0's Avatar
just installed the new beta drivers 196.34, rebooted and still doesnt appear... i'll reinstall Precision
i see all the other options.. except GPU Temps,
Main Rig
Canadian Eh ?
Old February 10, 2010, 08:35 PM
rjbarker's Avatar
Yes and when you re-install Precision click "no" when it prompts you to save all of your previous Profiles and Settings, this will ensure a "clean install"....oh..and "uninstall" old Precision first, you should be good to go ;)
Also....you did try "scrolling" down through all of the different options to look for "GPU Temp", it may not be right at the top.
Old February 11, 2010, 09:07 PM
ZZLEE's Avatar
Default IN Game
The tuner thing that posted the FRPS and temperture in games seems harder to find now to.
Glad you like my SIG" Hey ZZ....glad to see your using my "quote".....too funny!"
Old February 11, 2010, 09:13 PM
ZZLEE's Avatar
To get Riva tuner select "tray Icon" on monitering tab you should get an icon in taskbar with frame rate and in game frme rate and temprature :)
EVGA Precision v1.8.0 Update FiXT Press Releases & Tech News 1 August 19, 2009 10:04 AM
EVGA Precision 1.5 released Alwaysrun Overclocking, Tweaking and Benchmarking 3 March 8, 2009 11:16 AM
EVGA Precision changes to different profile automatically? chouchou Troubleshooting 1 February 2, 2009 12:55 AM
EVGA Precision - Crysis element291 Overclocking, Tweaking and Benchmarking 12 January 28, 2009 03:41 PM
Anyone try EVGA precision GPU tweaker? Babrbarossa Video Cards 7 May 4, 2008 09:06 AM
