Old February 10, 2010, 11:14 AM
Default Problem overclocking my E8400
I hit 3.6Ghz but for some reason CPU-Z fluctuates between 2.400 and 3.6...I have no clue why.
Old February 10, 2010, 11:16 AM
CMetaphor's Avatar
Quadfather
its called EIST. google it Basically, your cpu is dropping down multipliers when idling or with light use. Try stressing the cpu and check it again.
Old February 10, 2010, 11:17 AM
lol just checked it while playing Crysis Warhead and its back to 3.6ghz. phew though I messed something up...so this EIST thing is safe right? even if I plan on hitting 4ghz?
Old February 10, 2010, 11:27 AM
CMetaphor's Avatar
Quadfather
Perhaps one of the crazy OC'ers (*cough*3oh6*cough*) can check me on this, but I've never really turned it off unless I was going for a very high OC. Aka, I had it on w/ my E8400 @ 4Ghz, but turned it off to push past 4.5Ghz.
Old February 10, 2010, 11:38 AM
how could i turn it off?
also, I plan on going for the 5870 soon, should I bother upgrading my cpu to something lke the i5 750?
Old February 10, 2010, 11:40 AM
BT!'s Avatar
BT! BT! is offline
you should fill out the system specs in your control panel for the forums, that way people can see what your working with. it'll be easier for the guru's to give you OC'ing advice. :)
Old February 10, 2010, 11:41 AM
CMetaphor's Avatar
Quadfather
Well don't take my word for it, but it depends on the game and resolution you play at. That being said, an e8400 @ 3.5-4Ghz with a 5870 should be just fine for whatever you throw at it in most cases.
Edit:
Oh yeah, EIST can be turned off from the Bios.
Old February 10, 2010, 11:58 AM
awesome thanks. managed to hit 4ghz now.
Old February 10, 2010, 12:47 PM
That means new board and new ram too. $500-$600 upgrade
"What is the colour when black is burnt ?" - Neil Young
Old February 10, 2010, 12:48 PM
CMetaphor's Avatar
Quadfather
Thats good, but is it stable? OCCT dude...
Help with overclocking my E8400 Bloodmaster Overclocking, Tweaking and Benchmarking 1 November 15, 2009 08:01 AM
Overclocking E8400 2 Sharp-Shooter Overclocking, Tweaking and Benchmarking 20 April 27, 2009 02:54 AM
Overclocking E8400 Sharp-Shooter Overclocking, Tweaking and Benchmarking 13 April 18, 2009 03:56 PM
Need help overclocking my E8400 please BlueRice Overclocking, Tweaking and Benchmarking 3 December 12, 2008 03:27 PM
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
