Old February 9, 2010, 11:13 AM
rjbarker's Avatar
^^^ Read the previous Post "carefully" ....vCore vs vTT...besides 82c under full LinX load isn't anything to get concerned about, certainly wouldn't rush out to purchase all WC parts thats for sure. A DO Chip would certainly be justifiable though ;)
Anyhow, as I determined 8 months ago, the difference between 4 Ghz and 3.83Ghz considering the amount of additional vCore and increase in Temps isn't worth it.
Tri SLi "Procyon"
http://i30.photobucket.com/albums/c3...ant2/nice2.jpg
Evga 4.2 Ghz Club....
Tri SLi 580 MK11
http://i30.photobucket.com/albums/c3.../MK11Multi.jpg
Tri SLi 580 Vantage
http://i30.photobucket.com/albums/c3...ant2/60K-1.jpg
......Remember, keep your head up....and your stick on the ice
Old February 12, 2010, 06:50 AM
with thermalright Ultra 120 and 920 d0 you really can do better than that
Old February 12, 2010, 10:01 AM
rjbarker's Avatar
If your referring to my Post.....I am using a TRUE (Push / Pull)
As for te DO Chip, thanks I was completely unaware of the reduction in vCore required for a DO vs CO/C1 Chip
When I built my Rig a year ago thier were no DO Chips and I'm well aware of what my OC'ing capabilites are.
If your referrng to the OP then kindly disregard
Tri SLi "Procyon"
Tri SLi 580 MK11
Tri SLi 580 Vantage
Old February 12, 2010, 10:10 AM
vintank's Avatar
I have been fiddling a lot these last few days and I just can't seem to get it stable at 4gz, going to have to check the first template I used to hit it and try that one again, but currently sitting at 3.86ghz and stable
my temps are around 67 - 72C on full load which is fine by me with my current cooling setup the temps drop to around 63 - 65 if my ambient temp in the room is a little cooler but the room I am in is a little small for all the electronics I have as long as I
don't turn on my Onkyo 607 the ambient stays down but man when wife is watching TV or a movie that Onkyo produces some major heat, the only flaw in them IMO.
will post some new screen captures soon, and still trying to hit 4ghz stable with temps lower than 80C
on a different note whats the max temp you would want your gpu to get to mine while playing Crysis or MWF2 is getting up around 75C in my obsidian with the fan running at 75%, for noise reasons I don't want to go higher than that.
DK P35-T2RS / E6750 / Crucial Ballistix PC2-8500 x 4 / Thermalright Ultra 120 / BFG 260 Maxcore / Antec 900/ GameXstream 600w
EVGA X58 Classified 3 SLI / i7 920 D0 / G. Skill Trident 3 x 2GB DDR3-2000 / Noctua NH-D14 / BFG 260 Maxcore / Corsair Obsidian 800D / Seasonic M12D 850w
Old February 12, 2010, 10:19 AM
rjbarker's Avatar
Imo...thats as warm as I'd want it to get when gaming.......under full Testing Load you shold be considerably higher than when gaming. Don't be surprised if you need a significantly higher Vcore to get from 3.8 to 4......
Have fun ;)
Tri SLi "Procyon"
Tri SLi 580 MK11
Tri SLi 580 Vantage
EVGA P55 Classified, EVGA X58 Classified, Core i7, New SATA? -ConfuseD- TokeR New Builds 8 December 7, 2009 12:13 AM
[FS] EVGA Classified X58, Corsair Dominator GT 2000MHZ DDR3, Intel Core i7 920 D0 FtGF Buy/Sell & Trade 21 September 22, 2009 01:55 PM
EVGA Announces GTX 285 Classified and X58 Classified 4-Way SLI Motherboard voklskier4452 Press Releases & Tech News 38 September 9, 2009 04:17 PM
EVGA X58 Classified belgolas CPU's and Motherboards 121 April 6, 2009 05:52 PM
VR-Zone & EVGA Forums - EVGA X58 SLI Classified - NF200 Monster! zlojack Press Releases & Tech News 26 March 19, 2009 07:05 PM
