I would follow the below guide. I take no credit for these settings.
If your only using 2 sticks of ram 1.2V on NB should be fine.
Originally Posted by Lsdmeasap Sure thing man, hee ya go. For 8GB you may need more MCH Voltage and to adjust tRFC and possibly some other timings >>>>
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto or Fast
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................: 4.05
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 450Mhz
PCI Express Frequency (Mhz) .........:Set to 100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< 800
PCI Express Clock Drive.................: <<< 900
CPU Clock Skew (ps)....................: <<<
MCH Clock Skew (ps)...................: <<<
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 2.00D (2.00B may work for you as well, it would be better but is harder to get stable often at high FSB) This is 900Mhz, you may also try 2.66D for 1066 but it may take some tweaking of MCH Voltage
Memory Frequency (Mhz) ..............: 900Mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................15/18
Advanced Timing Control
tRRD...........................................3-4
tWTR..........................................3-5
tWR............................................4-6
tRFC...........................................52-62
tRTP...........................................3-5
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength ............................800/1066 (Benchmark/Test both last, set 1066 now)
Channel A
Static tRead Value.........................:6/7-10 333/B MCH - 8/9-12 400/D MCH
tRD Phase0 Adjustment...................:<<< Leave for all below as well
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Motherboard Voltage Control
Voltage Type.
... Manual
CPU
CPU Vcore
.........................:1.25-1.36 Actual not bios settings (All up to your chip)
CPU Termination
..... 1.200V*.......: <<< 1.2-1.36 (1.2-1.28 likely plenty)
CPU PLL
....1.500V*.......: << 1.5-1.58
CPU Referen.
....0.755V*.......: <<< .64% Of Vtt (Termination above) Auto Will set this correctly
CPU Reference2
,,0.800V*.......:<<< .67% Of Vtt (Termination above) Auto Will set this correctly MCH/ICH
MCH Core
.....1.100V...........: << 1.2-1.3 (1.22-1.26 likely good)
MCH Reference
.0.800V...........; <<< Leave
MCH/DRAM Ref.
......0.900V...........: <<< Leave
ICH I/O
.....1.550V............: <<< 1.5-1.6
ICH Core
1.100V............: <<< 1.1x-1.2
DRAM
DRAM Voltage
....1.800V............: 2.0-2.1 (Check your ram sticker)
DRAM Termination .
0.900V............: <<< Leave
Channel A Reference 0.900V............: <<< Leave
Channel B Reference 0.900V............: <<< Leave
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled] Enabled if you use Vmware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect ..............[Disabled] *Note* Must be enabled to flash from USB |
