-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   good ram timings? (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/28235-good-ram-timings.html)
kuziwk January 26, 2010 06:59 PM
good ram timings?
patriot viper series 2x2gb 5 5 5 15 stock, what would be a better ram time. Also what ratio would be the best? 440 cpu fsb currently
bovine.baron January 27, 2010 10:33 PM
From what I've read, if you got any performance increase, it would be from lowering the middle two timings (tRCD and tRP) but given that you have a sufficient amount of memory you probably won't notice any difference.
Silvgearx January 29, 2010 08:31 PM
DDR2 Frequency > Timings
Just set the ram divider and let SPD handling the timings.
LarkStarr January 29, 2010 11:29 PM
lower timings are better, but less stable.
as mentioned, obtaining a higher clock is better then adjusting the timings.
though if I'm not mistaken, adjusting the first timing (tCL or CAS latency) has the most effect (I could be wrong)
the best ratio is the one that makes your ram go the fastest without crashing :P
what speed is your ram stock?
-=CrAnSwIcK=- January 31, 2010 12:58 PM
yeah i would have to agree...overclocking the RAM will give you the most benefit performance wise, otherwise when you reach the frequency wall for your RAM at their max rated voltage, you can either overvolt them or you can loosen the timings, otherwise don't bother with the timings...i wouldn't recommend lowering the timing on overclocked RAM...
