This post in a update to my earlier post of my ram not running above 667Mhz. I have Four 1 GB sticks of Kingston KVR667D2N5/1g in my rig. I was having problems trying to get my Ram to Overclock. I kept hearing the same thing,"Having Four 1 GB sticks will not Overclcok as easy as having just two 1 GB sticks of DDR2 667Mhz." Someone on another site suggested I put my Cpu back to stock speeds and try running my ram at a 2:3 upclock divider. So I did. Cpu at 2.13 Ghz, Ram at 800Mhz
,5,6,6,18 2.1 volts. So now with this new info it is clear that My four 1 GB sticks of DDR2 667 Kingston Value Ram can run together at 800Mhz. I ran Three apps of memtest, one test 1024, one test 1024, one test at 510. That seems to be all the Ram Win XP 32 bit can "SEE". It ran to over 100% coverage on all test without errors. Well that brings a small smile. At least I know now that All four Sticks of Ram "Get along" at 800Mhz. Well were do I go from here. I have been testing things out since finding this info out. I can get my CPU to run at 2.8Ghz v.core 1.25, Ram at 700Mhz 5,6,6,18 2.1 volts. I tried to get to post at 2.81Ghz and no go. I don't know what else to adjust. I upped the CPU Volt to 1.35 and still no luck. So please guys, There has to be a way to get this Rig to run at least to 3.0Ghz. I haven't upped the North Bridge yet cause I can't locate it. So some advice would be great on where is the NB volts are, as well as anything else I could try to get up to 3.0 Ghz.
Thanx
