Old January 19, 2010, 05:36 PM
Default ASUS P5Q-E + E8400 E0 - first time OC
Hi Everyone,
Well I actually built my PC last year but have never got around to over clocking it. I have never OC'd anything so I have spent quite a while just researching and reading some of the posts here. I know there are a bunch of guides online for e8400's but I had a few specific questions so I thought i would make a post specific to my build. This is what I currently have.
ASUS P5Q-E (latest bios)
Intel e8400 3.0 E0
gmatek's Dark Knight S1283 HS
Mushkin RL 2x2GB DDR2 PC2-8000 5-5-5-12
GTX 260
Corsair HX620
Running just at 3.0ghz It sits idle at around 29 to 30 degrees. So reading some other threads on here I thought I would just take it easy and try to go 3.6. In the BIOS I made the following changes:
- set AI OC tuner: manual
- FSB - 400
-CPU ratio setting: 9.0
-CPU Voltage - 1.3
-DRAM Volatage - 1.9
So now I've booted up now and everything seems ok. If i bring up Core Temp it is now sitting at 31-32 degrees at idle.
One question i have is under the Frequency section it keeps flipping back sometimes between 3.0 x 6 and 3.6 x 9, is that normal? or is it just supposed to stay at 3.6 x 9 all the time?
This is the part i'm a little confused on now, so to make sure it is stable i should run Prime95 for 8hrs or so and see if it passes everything?
I've have it running right now for about an hour and it sits around 45-48 degrees. Is there any other tests i should run? Is there a specific test i should be using on Prime95? Sorry for all the questions just a little nervous about messing anything up
Also I'm not sure if i should be making an memory specific changes?
Old January 19, 2010, 06:10 PM
ZZLEE's Avatar
Default cpuid hwmonitor , CPUZ
http://www.cpuid.com/download/cpuz/cpuz_153_setup.exe USE this
http://www.cpuid.com/download/hwmoni..._108_setup.exe and this
Old January 19, 2010, 11:25 PM
burebista's Avatar
Yep, that's called EIST/C1E. It's a feature not a bug.
Run prime95 Small FFTs (for heating CPU mostly) or Blend (to test the memory too) and monitor your core temps with latest RealTemp. Also if you're brave run 5 passes of LinX with All memory selected.
If it ain't broke... fix it until it is.
Old January 20, 2010, 12:43 AM
Ok great, i'll run Prime95 and real temp over night to see how it does and post back with results
Old January 20, 2010, 07:03 AM
Sorry to hijack but I have a similar setup with Asus P5Q and a E8400 C0.
Trying to get past the 3.6ghz barrier [ran stable with 20 passes of linx with all memory selected ]
But LinX keeps failing at like the 3rd pass =( . How should I continue to tweak the settings to see what's causing the error stop?
Intel i7 6700k (4.6 ghz) w/ Corsair H100i V2
EVGA 1070 SC
2x8GB GEIL Super Luce 2400hz
500gb SG + 2TB WD20EARS + Intel 300 240gb
Corsair TX650W
Asus Z170i Pro Gaming
Corsair Air240
Old January 20, 2010, 08:10 AM
OK quick update, I ran prime64 all night so around 8hrs and it seems fine, all tests passed. It ran between 48 - 50 degree's the entire time.
Just ran LinX with all memory selected and 5 passes. Finished without error in 17m with the temps being around 57-60 degrees.
So this is all good? Is there some more testing I should do? what would my next steps be
Old January 20, 2010, 11:53 AM
Hey bedouin, so I'm assuming you hit 3.6 stable now correct?
Now you're where I am, getting past this 3.6 though your lucky, you have the E0 :(
I'm trying to hit 3.8 at the moment with no luck.
EVGA 1070 SC
Corsair TX650W
Corsair Air240
Old January 20, 2010, 01:17 PM
burebista's Avatar
I'm not a clocker but for me 8 hours of prime95 and a quick 5 passes of LinX are more than enough for stability. :)
Your temps looks perfect fine so ask for more.
Old January 20, 2010, 03:04 PM
Dashock's Avatar
i have a E3110 and i was running it at 4ghz without a problem
CPU-Z Validator 3.1
Now i did this with a modded bios from Ket im still using the same bios and i have Mushkin ram like you and its the same module just i got the Ascent heatsink.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
E8400 and asus p5q-e does not start marse Troubleshooting 12 October 5, 2009 01:29 AM
can't seem to get stable. e8400 + P5Q-Pro. Please help. The MAX Overclocking, Tweaking and Benchmarking 14 March 25, 2009 03:03 PM
E8400 @ 3.6 P5Q-E Help kuro89 Overclocking, Tweaking and Benchmarking 25 March 11, 2009 04:37 PM
Overclocking e8400 on a p5Q pro serenity CPU's and Motherboards 10 February 4, 2009 04:57 PM
Asus P5Q-E and E8400 OC help Alwaysrun Overclocking, Tweaking and Benchmarking 39 October 11, 2008 12:29 PM
