Old January 19, 2010, 06:50 PM
Right now I've settled on a 3.6 Ghz OC for my i5 750.
When running Prime95 large FTT (max heat generation) my max core temps are 57 54 53 54
Settins include:
Multiplier = 20x
Blck Frequency = 180 (set in BIOS)
DRAM frequency = 1440 Mhz (set in BIOS)
DRAM voltage = 1.65v (set in BIOS)
CPU Voltage = Auto (set in BIOS and CPUZ shows 1.256v)
FSB:DRAM = 2:8 (according to CPUZ)
Also have the following:
Intel Speedstep = Enabled
Intel TurboMode = Disabled
C1E Support = Enabled
Intel C-State = Enabled
Old January 19, 2010, 06:56 PM
LinX will push your processor harder than any load you can normally generate.
That's why LinX will crash at the slightest hint of system instability.
i5 750 voltage? Draex Overclocking, Tweaking and Benchmarking 11 December 31, 2009 07:04 AM
Which is the best? 750 or 860 MarkOne Overclocking, Tweaking and Benchmarking 6 December 31, 2009 06:40 AM
i5 750 @ 4ghz Fudd Rucker Overclocking, Tweaking and Benchmarking 4 December 16, 2009 12:56 PM
I5 750 Problem MikeScott Overclocking, Tweaking and Benchmarking 27 November 27, 2009 04:05 PM
