Old January 30, 2007, 05:17 PM
sizerkozak's Avatar
Default Kentsfield and the 680i advice
So now that i have my chiller functional im actually gettin to OC my 6700 finnaly....WOOT
I can get a stable 3733.1 MHz @ 1.5v and 13C idle temp
However i cant seem to push the FSB up at all.....should i not be able to get a little something out of it?..
what are you guys getting?
and how?
What should i be looking for regarding memory ?
is it even worth worrying about it since i cant budge the FSB at all ?
Here are a couple pics of before and after OCing
BEFORE OC
AFTER OC'ing
QX6700
ASUS P5N32-E SLI
BFG 8800 GTX
OCZ DC 2048MB PC8500 1066MHz DDR2 SLI
RaptorX 150GB 10K RPM
Three LGL1919S & 3HeadToGo
BFG 1000w
-20C Liquid Chiller
Rig Pics and Stats
Water chiller project
Monitor mod
Old January 30, 2007, 10:56 PM
Deathspawner's Avatar
Grats on the overclock as is.. it's sweet. The lack of FSB almost makes me cry though... you are not able to increase it at -all-? I assume you cranked your NB voltage a little?
I doubt your memory is the problem... it's very high-end. You -could- tweak it to at least 4-4-4-12-13 (cas trcd trp tras trc) 1T 2.1v. That still won't make much of a difference compared to higher FSB though. I'm not -that- familiar with that board, but do you have the latest BIOS?
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
Old January 31, 2007, 03:04 AM
Misoprostol
Guest
Posts: n/a
See my thread here. I feel your pain. No fix yet.
Old January 31, 2007, 05:11 AM
Babrbarossa's Avatar
Yeah-- evga tech jacob made it sound like the fix would be along within a couple of days, but it's been almost two weeks since he announced it. I guess they wanna keep selling the boards to quad core owners.
Old January 31, 2007, 10:02 AM
Supergrover's Avatar
Yah right.
This is one of the reasons that I dont particularly like Evga mobo's they are far from quick to do bios updates and when they do most of the problems arnt fixed.
Like fix the memory issues dont just add CPU support, that doesnt fix **** IMO.
R.I.P.
Old January 31, 2007, 11:31 AM
It seems that this time, though, while they did release the mobo prematurely (as companies usually do), they have already released 4 bioses in just a couple of months, and while they haven't quite got it right yet, they seem to be putting in a valiant effort, and I have to say that their customer service is good.
edit: just to rave on a bit further- I do really like my 680i and have never had trouble with it. The new bios has helped me bring my overclock from 3.2 to 3.4, and the components all seem to interface well together on this board for me-- I don't think you could reach 10.5k on 3dmark06 with another motherboard with my components.
Old February 2, 2007, 12:39 PM
Misoprostol
Guest
Posts: n/a
Early Feb. is the ETA for the FSB fix :)
Old February 18, 2007, 01:46 PM
Actually, it won't be until early March. jacob mentionjed that it is Chinese Newyear and the engineers are off until Feb 27.
Old February 18, 2007, 09:37 PM
Misoprostol
Guest
Posts: n/a
yeah... w/e. I'm glad I don't have an eVGA board anymore.
Old February 19, 2007, 02:06 PM
Yeah, but you stayed home for your christmas- you probably wouldn't bee too pleased if a chinese teacher demanded you give up your x-mas holiday, just because it didn't align with his--
Need some advice....Please lol. cdn_Madrach Troubleshooting 9 May 30, 2007 04:47 PM
Is someone able to OC FSB higher than 300MHz on Kentsfield francois methot CPU's and Motherboards 13 April 23, 2007 10:44 AM
Kentsfield overclocking on nVidia reference 680i motherboard Misoprostol CPU's and Motherboards 34 March 26, 2007 10:52 PM
Kentsfield Sub-Zero OVERCLOCKING and Geforce 8800 GTX Benches! Misoprostol CPU's and Motherboards 22 February 14, 2007 01:07 AM
Kentsfield Review by HardwareCanucks Gav CPU's and Motherboards 0 November 8, 2006 10:53 PM
