So far it's been stable for 3.5hours of LinX @ 3.6ghz, ~65 loops, I'll have it testing for 250 loop to make sure it's stable, should be done by tommorow morning.
The temps went down by quite a notch!
Low 70's > High 50's for 3.6ghz
Low 90's > Mid 70's for 4.0ghz
I'll keep it at 3.6ghz if stable since the voltage is ultra low (1.141, 1.176 @ 100% load)
Thermalright Venomous X @ max pressure (70lbs?) strapped with 2 San Aces @ 2000RPM (quiet! I can stand 3k daytime, not while sleeping tho ^^) good news : No need to sand the base, it's mirror finish and pretty clean!
Using IC7 as TIM using an hybrid between these 2 methods of application to make sure there's TIM everywhere;
Verrrrrry happy with the results so far, will post pics of the final results :D
*Note that I'm not on my computer while typing this, so I can't take SS*
