Old January 30, 2007, 06:29 PM
Babrbarossa's Avatar
Super Moderator
Do y'all agree that he's probably ok with that psu for a while-- not ideal, but it's a good 550.
As for the nb and sb, I saw some pics of what people were finding underneath the ones on the 680i's and it was rediculous how much compound had oozed out around the chips, making a nice warm blanket.
Here's a link for instructions and some of those pics:
http://www.evga.com/community/messag...TOPIC_ID=24455
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old January 31, 2007, 05:38 AM
Level up: 99% Level up: 99% Level up: 99%
Level: 8 - 1 points to level up
Wow what a mess that putty was. For sure that will be replaced before the new board goes in.
The PSU I'm confident is fine for one Geforce 8800 GTS since there are two pci connectors on that PSU and I'm using only one of them. Only one 80 gig HD, one DVD two 120cm fans plus the water pump. Thanks for the input.
[SIGPIC][/SIGPIC]
Asus P5K-E wifi-AP
Intel Core 2 Duo E8400
4GB 2X2GB PC2-6400 DDR2-800 CL4-4-4-12
EVGA E-GEFORCE 8800 GTX 575MHZ 768MB
Raptor X 150GB 10000RPM NCQ SATA Windowed
WD SE16 500GB SATA2 7200RPM 16MB Cache 8.9MS
PC Power & Cooling Silencer 750W
Samsung Lightscribe DVD/RW
Hiper Anubis Case
Old January 31, 2007, 07:24 AM
Super Moderator
yeah-- those 8800gts cards only use up to 110 watts as opposed to (i think) 160 for the 8800gtx
Old January 31, 2007, 09:55 AM
Supergrover's Avatar
Super Moderator
With every new card/board I always reapply the TIM ( thermal Interface Material ) half the time all thats on there is those stupid putty strips ( gak:( ) or its some generic white paste put on by a one armed monkey.
If it's a mobo 90% of the time I replace the NB cooler as most are complete crap.
Rocket Surgery-A Combination of Rocket Science & Brain Surgery
Nothing in Moderation
Problems with your DC Order? PM Direct Canada's Forum Rep
Old January 26, 2008, 12:09 PM
If you're really scrimping for $$, go with an E2xxx series CPU. My e2180 plays Crysis with no issues, everything high, AA 4x, 1650x1080 resolution. Granted I do have an 8800gtx, but I was in a budget situation so I got the better gpu and scrimped on the cpu.
As I was writing this I noticed you already have the gtx. So nevermind...
Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900.
Intel E1xxx & E2xxx OC Thread
8800 GTX $339 after MIR. belgolas Hot Deals 5 March 21, 2008 04:14 PM
An 8800 for 100$ Is is possible? TwystedMonkey Video Cards 27 March 20, 2008 05:08 PM
8800 GT SSC v. 8800 GT (EVGA) Inhocmark Video Cards 8 February 26, 2008 03:13 PM
AMD answers the 8800 GT... qwerty Rumor Mill 19 November 14, 2007 10:10 PM
Fubarred 8800 GT? enaberif Troubleshooting 0 November 14, 2007 12:16 AM
