Old January 5, 2010, 07:18 PM
Rocco_360's Avatar
I'll try out what you got there rjbarker. Yes I do have an EVGA X58 3x SLi board with Corsair Dominator 1866mhz ram. I have it set to 2:10 which says 1333 but its running at 1763 from the looks of it.
Really Arinoth 1.35-1.375? Hmm that seems really high :S
Cooler Master HAF 932 || EVGA X58 3x SLi || Intel Core i7 920@ 3.7GHz || Corsair Dominator 6GB DDR3 1866MHz || EVGA GeForce GTX 275 FTW || Corsair TX850w || Auzentech X-FI Forte 7.1 || Western Digital Caviar Black 1TB || Seagate Barracuda 500gb || Corsair H50 CPU Cooler ||
Old January 5, 2010, 07:30 PM
Arinoth's Avatar
Not really. Most C0/C1s need 1.4V Vcore to hit 4+ GHz OC. Anything 1.4 and lower is still safe for the cpu and well its not a D0 so you can't mirror your OC to a D0 one since C0/C1s just plain need more Vcore and Vtt.
Old January 5, 2010, 07:37 PM
rjbarker's Avatar
Not enough Vcore for a C0/C1, you need about 1.35 -> 1.375 V typically
Not true at all......for 3.6 - 3.8 Ghz even a C1 Chip (which I have) may not require that kind of Vcore....!!
To OP....you have 1866 Mhz Ram...then go ahead and try my settings. .....with 1866 Mhz ...you should be able to find the "sweet spot" running your RAM at stock.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old January 5, 2010, 07:38 PM
Arinoth's Avatar
There are some golden C1 chips though, mine needs 3.375 to be stable at 3.8 GHz to do big adv wu's
Old January 5, 2010, 07:46 PM
rjbarker's Avatar
Mine requires 1.31875v. and +125mv Vtt..stable at 202 Blck x 19 Mult (no turbo).....maybe its a great chip...no idea.....any less Vcore will not pass LinX....I spent a lot of time finding this "sweet spot"...
30 passes Linx and 18 hrs P95......
Max Temp 67c
Old January 5, 2010, 07:55 PM
Arinoth's Avatar
Big Adv Work Units also stress the cpu and OC more then LinX does, its the ultimate OC stress test but really only need to stress test it that hard if you are folding on it (kinda the double edged sword)
Old January 5, 2010, 07:56 PM
Rocco_360's Avatar
Interesting. NOO CANADA JUST LOST THE JUNIORS WHYYYYYYY!? Haha had to say it sorry :P
Who's not folding because of the heat? badatcards HardwareCanucks F@H Team 34 August 21, 2009 10:47 PM
heat issues ToXic Video Cards 4 August 21, 2009 05:33 PM
Has anyone ever tried routing their pc's heat? Z Overlord Air Cooling 2 July 21, 2009 07:39 PM
Has anyone ever tried routing their pc's heat? Z Overlord Water Cooling 14 July 18, 2009 02:42 PM
Heat Issue Lyxtwing Video Cards 8 March 14, 2008 08:35 AM
